DarkMatterGrey
- Joined
- Jul 17, 2024
- Threads
- 20
- Messages
- 326
- Reaction score
- 317
- Location
- Scottsdale AZ
- Vehicle(s)
- 2024 GT Dark Matter Grey 6 Speed Manual "Job 1" (no start/stop)
It is not required for S550 or S650 Torsens. It won't hurt and it is not already in the Motorcraft fluid that Ford sells by the quart over the counter. I can't say that it's that way if the shop or dealer have it already in bulk or use fluid from a different vendor (Amsoil, Valvoline, etc.) which may already contain some modifier. The reason some are sold without modifier is open, locking, and Torsens don't require it, only limited slip with clutches typically do.They still use Friction modifier...when I had my 4.09s installed in my Torsen the shop did the work put the Ford Friction modifier in as it was in the Ford diffy lube that was used.
Different question, was this on a S650 Mustang? If so, how did you reprogram the computer for that ratio so the speedometer and odometer are accurate, Forscan, Ford FDRS, other?
