Correct Torque on Gorilla Small Diamter Lug Nuts
MidLifeCoyote
Peoria Illinois
I have tires mounted on my new Velgen Classic5 V2 wheels and plan to put them on my 2024 GT this spring. I have the Gorilla small diameter lug nuts from cj pony parts (part#WHLLN16). They are 3/4 vs factory 13/16.
I know factory lug nut torque is 150 ft lbs. Do I still torque these small diameter lug nuts to 150 ft lbs?
I searched and found a few threads with confusion on this topic. Just wanting to verify.
Thanks
I'd check with Velgen and Gorillas for their recommendations. Otherwise, I'd use the one in the manual.
I suspect because the stud size has not changed, the factory specification (150 lb-ft, 204 nM) will be used.
GrabberB
As others have stated 150 ft. lbs. If an aftermarket company is making a product that is unable to meet factory specs. said product would be a fail.
I suppose you could check with the manufacture to be sure. I would expect they will confirm factory spec. of 150 ft. lbs. As stated above anything less would be a fail in my opinion.
TUnica
South Hero VT 05486
So I have the exact same set up, I spoke with Gorilla about this and they said 125# tops. I have been running this setup for the past year and have periodically checked the torque and no issues.
Velgan will tell you the same - 120 to 125. I would NOT torque to 150 with the smaller lug, but some do. If it striped or broke, thats going to be an expensive day. I kept my torque wrench in the garage and checked it from time to time just to satisfy my concern.
MidLifeCoyote
Peoria Illinois
I see you had an earlier thread on this topic. It appears you are using the splined lug nuts and I am using standard type. Was the quote from Gorilla and Velgen of 125 ft lbs max only for the spline design, or for the smaller diameter design in general?
TUnica
South Hero VT 05486
I spoke to both, Gorilla and Velgan, both said 120 t0 125. Gorilla specifically to the spline at 125. If you have a standard hex lug nut I would think you would be OK with the 150. There was no way I could feel comfortable torquing the small spline to 150 and the Gorilla tech said "do not torque to 150".
Contact Gorilla for your specific lug.
MidLifeCoyote
Peoria Illinois
I have emailed this question to velgen and gorilla to ask, quoting the specific cj pony parts part number. Assuming I'll hear from them early next week.
Mustang6G also had a thread on this with many different opinions.
Ken H.
Wyoming, DE
I have Gorilla small diameter spline duplex lug nuts (short on front, regular size on rear) on Ferrada CM2 20” wheels. I texted Ferrada & Gorilla today. Ferrada says follow manufacturer’s specs (not sure if they mean Ford or Gorilla). Gorilla says 100-110 ft-lbs. I’m currently at 150 per Ford. Confused.
