Coolant colors ❓️
D/\rK•650
2025 Mustang DarkHorse
So is everyone's coolant turning that yellow brown color? Im wondering about mine now since its no longer that bright yellow color. I just mean about the color turning a bit from an engine issue. Maybe the color alone shouldn't be something to stress about? Im OCD about stuff like this. Anyone have coolant that still bright yellow after many miles like over 10 15k?
Thank you for reading 📚
There is another thread about this on the forum. Yes, over time the coolant does turn darker and its normal. That said, it shouldn't be DARK, and it shouldn't be sudden.
Can you post a picture of what it looks like?
D/\rK•650
D/\rK•650
Im sure im overreacting its still pretty yellow it just isn’t quiet as bright as it was new. Next time I look at it if I think I should post a picture I'll do that. Thank you though
Neggytive
They make test strips to check coolant for proper PH ( acidity or base) and freeze and boil points if you are concerned about the condition of your coolant
Same thing for brake fluid, it will test Ph and water content, above 3% water content is really bad for brake fluid.
You can actually test brake fluid and coolant with a good volt meter too
D/\rK•650
D/\rK•650
Yes im getting a few tests to check it just for peace of mind. Thanks for recommending
Yeah its normal for bright yellow coolant to get darker as you put on mileage. I wouldn't worry about it unless you are also losing fluid.
Charger68
Willoughby, OH
2025 Ford Mustang GT, 2016 Dodge Challenger RT, 2013 Dodge Charger RT
Using undistilled water will turn coolant brown, should you add water to OAT coolant. Always use distilled water. Otherwise, coolant does turn darker over time.
You should be adding Motorcraft prediluted Yellow and nothing else.
Ryunker
Madison South Dakota
This is great info, I have been doing this for decades. The op isn't really concerned about the coolant life, more over concerned it may be contaminated.
Charger68
Willoughby, OH
Yeah, I can find Motorcraft now, and the $10.00 Prestone Purple stuff I use in my Mopar's. Mopar's OAT concentrate was the same price as their 50/50, $32 bucks, and so I would add distilled water.
D/\rK•650
D/\rK•650
Thank you❗, as Ryunker has stated this is great information. 👍
