Amarii
FL
2025 Mustang GT Premium
Welcome to my write up I have done. I see plenty asking about adding active exhaust, or regretting not adding it. I have confirmed most of this is also going to be mostly same for 2019+ mustangs, sadly not the 2018.
The wire harness going back into the trunk is the same on the cars between non AE cars, and AE cars. All of the features are turned off in your tune for non-AE cars, and turned off in all the modules related to center screen.
You'll need these parts
(2019+ ae parts that are different
1*JR3Z-14A411-J wiring harness (Y harness)
2*JR3Z-14A411-H wiring harnesses (from Y to actuator)
2* JR3Z-6554-A Exhaust Valve Actuator)
1x AE mufflers - bought used 150$ for both from marketplace.
2x PR3Z-14A411-A, Actuator harness, 53$ msrp new
2x PR3Z-5K245-B, (PR3Z-5K245-A -this was replaced by xx245-B) Exhaust valve actuator,
msrp around 100$ each,
(135-170$ on ebay each on ebay) I got mine used off marketplace 170$ for both.
2x JR3Z-9449-A Actuator Spring, these usually come with the actuators, but if it doesnt, you need these.
1x PR3Z-14A411-C, Y-wire harness that connects to car harness and evap, new for 56$
2x Heat shields for actuator, 22$ a piece, Ebay. sometimes the actuators may have these with them already. not really a part number, but bmw and some other manufacturers use the same heatshield. Easy enough to find.
6x M6 nuts to mount actuators, if they dont come with it.
OBDII to usb chord, use forscans website for guidance on the correct one. I used a different one and that cost me 30 bucks. Forscan is free to use.
I included what I paid for all the components, and my overall costs. I did not include my tune device, a MPVI4, and credits, because most people will already have a tuner, or plan to get one anyways if you are modding your car.
My costs all together was 543, and I just had a buddy weld them on for me.
alot of this stuff is readily found on either ebay, fb marketplace, or ford directly.
For Forscan you have to change settings under three module APIM, IPC, ACM
Instrument Panel Control (IPC)
720-06-01 xxxx xxxx x*--
Selectable Drive Mode (SDM) • Dual Exhausts (DE) • Exhaust Mode Button (EMB) • Eco Mode RTT (EMRTT) (EMB=Exhaust mode selection in the centerstack)
720-10-01 *xxx xxxx xx--
Transmission Temperature Curve (TTC) • Tunable Exhausts (TE) • Cross Traffic Message (CTM)
Accessory Protocol Interface Module(APIM) (SYNC)
7D0-09-03 xxxx xxx* xx--
Drive Control Menu (DCM) • Tunable Exhausts (TE) • Engine Rev Match (ERM)
7D0-09-05 xxxx xxx xx-- • Quiet Time Exhaust Mode
727-01-03 xxxx xxxx x-- Audio Control Module(ACM) • Active Exhaust Signal (AES)
I think I got everything here, basically anything related to active exhaust I turned on,
Then, ECU/PCM needs to be updated to enable AE install tune. Once in vcm suite, simply enable Active exhaust and other functions, or your tuner can do this. Takes seconds to do, and no need to change anything else on stock tune.
If after installing you get a feature is unavailable pops up in the center console, you either installed the spring that is connected to the actuator wrong, which will cause a error. Getting the spring installed correctly is a pita, and nothing online really about it. mine threw errors till I got it lined up properly with the flap. The system also needs time to calibrate itself.
assembly is get mufflers welded on, attach y-harness in the trunk, it is at the back with the spare tire, push through the trunk, and disconnect from evap plug. for s650 will need to remove a panel piece on the bottom to access most of it comfortably. attach y harness to car harness, evap plug, and the two wires going to the actuator harness, run along a flat section, and have two points they mount too. theres a longer section going too the passenger side. Actuator harness goes to the actuator, which attaches to the heat shield, and spring on the other end. 3x M6 nuts hold it together. Now all attached, open forscan, make changes in APIM, IPC, ACM, and then turn on active exhaust settings in the tune.
my inspiration for this was, I wanted quad tip exhaust. Single tip looks weird imo. Picked up two active exhaust mufflers for 150, and I got to thinking from there.
Pretend I am talking in the videos, cus I plan to eventually dub audio on the videos and to a full video walkthrough.
First video, shows the Y harness location, disconnecting it.
second shows the y harness, and actuator harnesses connected to the actuators,
3rd shows everything connected together from under the car.
thank you
S650 Mustang Confirmed! Adding OEM Active Exhaust to S650 (DIY how-to writeup) 1fc31053-3932-4a9d-b286-ce7115a599d3
S650 Mustang Confirmed! Adding OEM Active Exhaust to S650 (DIY how-to writeup) 20260710_213841
S650 Mustang Confirmed! Adding OEM Active Exhaust to S650 (DIY how-to writeup) 1dc74778-9ee8-4ae4-b9c2-395a9c064e8f
S650 Mustang Confirmed! Adding OEM Active Exhaust to S650 (DIY how-to writeup) 55c20a3c-82c4-4928-aa00-c6b46fd6c0c5
S650 Mustang Confirmed! Adding OEM Active Exhaust to S650 (DIY how-to writeup) b200eb30-d0a6-4f5d-adee-6e4b8bbe87e7
S650 Mustang Confirmed! Adding OEM Active Exhaust to S650 (DIY how-to writeup) 80ee2c42-0754-4316-89de-ed4d96eb9601
S650 Mustang Confirmed! Adding OEM Active Exhaust to S650 (DIY how-to writeup) d503f735-196e-4c0a-8aca-b3017cb667d5
What was the total cost for all that?
Amarii
Amarii
FL
Its in the post,
543 for parts and obd2 cable for forscan. and 200 dollars (4 credits) for my mpvi4(already had mpvi4 since I plan to get e85 tune, and eventually boosted) to write tune to my car. 200 I would spend for a tune anyways, but now I its married to car so for when I get a e85 tune. Mpvi4 I managed to get for 380$. Most people would have a rtd, tdn, from hptuners if they are modding car and just need to ask for that turned on in tune, so cost will vary for others, those are 299 or less usually.
Will2
'26 Mustang GT
Nice, congrats on accomplishing this. I think you're the first to successfully do this and detail the steps. A TON more work, parts, and effort than I expected, even requires a tune
Amarii
Amarii
FL
Thank you, I got some mufflers, since it ended up being cheapest way to get quad tips on my car, and turned into me looking to see if anyone did, only partial info out there and people debating it.
Wasnt sure it would work until I got the mpvi4 and took a look in the tune, which turned out easy to do, as shown in picture, you are just changing a few things from disabled to enabled in the tune, so not exactly as involved as say e85 tuning the car.
All together I could do it now pretty quick. Like 45 min job max. Sourcing the parts for cheap is more work imo. Lol
@Amarii ..... you did everyone a service AND you did a great job. Well done. I posted pictures, a while back, of an aftermarket part made specifically for the hole you cut. It fits over it, isn't expensive and looks factory OEM.
Amarii
Amarii
FL
Thank you! I am eventually looking at the darkhorse valance, I think it looks great, but going to see what other styling options are out there. But, if any others want to save and just make a cut, its easy to do, I have shown it can be done. 😁
NegativeMultiplier
Can you link the part? I'd like to do this for my Mustang at some point in the future, and if I can avoid having to spend $500 on a new valence or even $100-ish on Marketplace, that'd be great.
@NegativeMultiplier ....., Yes, happy to. I'll try to find the thread on this forum as it had all the details. If I can't I'll do some digging. I have seen the part installed at a Mustang meet and it looked absolutely oem. No way you could tell the owner cut the hole then added the trim.
RTR Vehicles
Concord, NC.
www.rtrvehicles.com
Mustang RTR
Amarii
Amarii
FL
Love the ingenuity here @Amarii!
We recently dropped our quad-tip conversion kit which converts the factory single tip valence to accept quad tips and would go perfect with your active upgrade.
Thank you, and awesome, I was just looking at these, they look great, will probably be ordering some soon!! I was going to post these here as well for the guys asking about a trim piece.
Mr Hyde
florida
2024 mustang GT
thank you
I your car a premium? just winding if the 301a base cars are missing more or is it just adding in harnesses, actuators, and mufflers. then enableing in forscan and tune?
Amarii
Amarii
FL
It is premium, I would take a quick look in the trunk, if you snap a picture of the connector there I could probably confirm, I imagine it should be possible on a base, I would think its on all trims that could possibly be optioned with AE, making one harness is cheaper than ford making a different one.
Zach@Granger
Gold Sponsor
Granger, IA
www.grangerford.com
2003 Cobra Mustang
thank you
Very nice! Thank you for sharing pictures!
