COLD AIR INTAKE
ChitownStang
Chicago, North Shore
2015 Mustang GT Premium
Drive shaft reduces rotating mass weight been there done that best model out of all the ones I listed.
You really noticed a lot with one piece drive shaft?
So many say waste of $ unless you are FI
Paul's stable
Maple Ridge BC Canada
2024 Ford Mustang GT Premium
Mods:
Pulled Carbon Traps
Two 1in Steeda Throttlebody Spacers
Swapped for K&N Air Filters
Corsa Double H Pipe
All Form Lighting for Side Markers, Rear Reflectors, Rear Break Light
DiodeDynamics Dome Light
RTR Rear Deck Lid
RTR Hood Scoop
Fathouse Performance Billet Cap Kit in Red
Added some colored bolts engine bay
two throttle body spacers? Do they make a big difference?
ChitownStang
It is a reduction in rotating mass.
like any mod, what has its value
Only issue I have is that you can end up with vibrations very easily.
To me it may not be worth the possible headaches where wheels are easy mod with my jack in the driveway
NWFreerider
Sagle, ID
2024 Darkhorse, HP, Tremec
Off topic of a CAI, I had QA1 carbon driveshafts on my previouse 2016 GT and 2018 GT350R. They were smooth as stock and half the weight. Stock 2 piece shaft weighs 30lbs. QA1 no longer makes driveshafts so I ordered a Driveshaft Shop driveshaft. Complete vibrating garbage. Just installed an aluminum shaft from Full Torque Driveshafts and it is 100% smooth, no NVH, and weighs 18lbs. But now I am questioning my Steeda intakes...
ChitownStang
Exactly my point , no time and energy to play with drive shaft problems.
Glad you got it figured out though and I’m sure you feel more instant throttle response which is what I want.
Throttle body spacers are a scam. Only useful if you need them to fit your intake back on etc
Joe_Stang
Glen Burnie, Maryland
I wouldnt say they are a scam. I've used them on other cars and felt a little better throttle response. But to each their own. I haven't bought them for the mustang yet though. If you are itching for a mod, they are cheap enough to scratch that itch. Rather buy them than cold air intakes for $600 plus
They don't do anything. It doesn't even make sense that they would work.
Joe_Stang
Thats a matter of opinion. Its always about 50/50 of people that are for/against them. At the end of the day its just a simple mod that isn't going to do much so take it or leave it.
