Will2
- Joined
- Nov 4, 2020
- Threads
- 28
- Messages
- 328
- Reaction score
- 255
- Location
- California
- Vehicle(s)
- '26 Mustang GT
For the benefit of anyone who stumbles upon this thread in the future: there are 2 different issues described in this thread.
Most posters are referring to 'transmission output shaft flange' lacking lubrication, causing a driveline clunk at low speeds or shifting between Drive <> Reverse). My 2025 Mustang had this, and TSB 20-2253 (technically for 2018-2020 Expeditions/Navigators) fixed it: https://static.nhtsa.gov/odi/tsbs/2020/MC-10179116-0001.pdf. Basically the same fix Xiaoqian and other posters wrote about. I noticed it most on 3-->1 downshifts rolling to a stop (10R80), just before full stop ~3mph.
The 2nd issue described in this thread is SSM 52444 (supercedes SSM 52428), clicking/pinging from a rear wheel when just starting to roll, or between forward/reverse directions. My 2024 Mustang had this, and it dates back to S550s (Ford still hasn't solved it?!). The SSM (Ford's version of a TSB-lite) is here: https://static.nhtsa.gov/odi/tsbs/2024/MC-10253687-0001.pdf
Ford procedure is to replace half-shaft + wheel hub, but the best video I found is a Ford mechanic describing the root cause (on 2020+ Explorers), where he explains his theory and fix without necessarily replacing those parts (5:00min mark):
2020 and Up Ford Explorer Ting Pop Fix - When put in Reverse and Drive Makes And Metalic Ting - YouTube
On S550 Mustangs there was the same/similar "thrust washer" issue, and many people replaced/removed them, but I think S650s may not have thrust washers anymore (like what the video mentions for Explorer generations too). If it's in-warranty, I'd just bring it to Ford for SSM 52444.
These are systemic issues across multiple Ford models/generations. Really wish we could buy a Ford built right from the factory, so we don't have to play diagnostic detective and re-do their work.
