Car feels floaty at high speeds?
Zathras
Austin
2018 Mustang GT
I think the reason some people are down on the performance package is because 1) it's climbed a lot in price over the last 5 years or so (from $4000 to like 6500), but the basic equipment you get hasn't changed much; and 2) Even after spending the money on it, people found out that the car is still not exactly track ready (i.e. it's not comparable in performance to the 1LE package)
IMHO a lot of the PP1 equipment should be the standard equipment level on the base GT. If they wanted to keep costs down they could drop the Brembos, Torsen, and the wing as standard, but make the PP1 bracing, shocks/struts, wheels & tires standard.
Of course if Ford made the base car actually good, there'd be less incentive for people to pay thousands more in options, and that's what Ford wants. Ford doesn't give a single fuck what Nurburgring lap time a base Mustang GT can do.
Stratman397
Seneca,SC
Question for everyone that got there s650s already. I picked my car up yesterday and it drives great and it's unbelievably smooth. However one thing I noticed is that at speeds exceeding 100km/h (60m/h), the car feels very floaty/loose. Like I'm driving on ice or something. Is this normal? My tire pressure is at 40psi so I was wondering if maybe it could be because of that.
My tires are 36 each, no problem when I,go that fast
Stratman397
Seneca,SC
I’ve got it at the recommended 32psi. The cars are transported at higher pressures. I don’t remember the reason why. (I think it’s to avoid developing flat spots if they’re sitting a long time 🤷) Dealers are supposed to lower pressure before delivery.
Mine are 36 each but I have hit 60 with no problems and no magneride
wilkinda65
Sun City Center, FL
You would be surprised what an additional 4 psi difference will do at that pressure. My car (2020 GT500) was set to 40PSI COLD and when I got on the interstate it starting increasing and the car was like on ice skates with the steering. Got off and set pressures correctly and big difference
IFFV68
I always go a couple of pounds over.
The recommended tire pressure is for a softer ride.
I also rotate the tires on every oil change.
Regardless of Mileage.
Seo124
TX
2024 mustang gt
Had Mine out a\on a clear and open road. I had to back off at 122 mph. Rock solid!
DukeCLR
Vermont
Sounds like th OP had the same issue I had, I'll check my tire pressure tomorrow.
Good luck rotating the tyres on a Mustang!
The recommended pressure is optimised for the road
RLE55
38.9967° N, -84.6310° W
36 psi, tires cool is whats recommended. Remember your physics 101 class, for every increase or decrease of 10 degrees air temp, tire pressure will rise or drop 1 psi. Also keep in mind as you're driving your creating heat in the tires, so it's not unreasonable for tires to reach 40+ on warm sunny days.
IFFV68
I’m very new to the new Mustangs.
My last one was a 1980.
I’ve had a few rentals in the past.
I’m 76 & ordered the 2024 GT Premium for the, I hate to say this but, may be my Last ride.
Thank you for your reply & any information will seriously help me.
i’ve been reading everything I can on the new 2024 Mustang.
thx again.
This is a great Forum.
Logan
Illinois
2003 Mustang GT
I've had my DH up to 128mph not problem with handling.
Carter1776
Indiana
2024 Mustang GT Atlas Blue
i run my GT at 30-31 psi in the front and 31-32 psi in the rear COLD, with Nitto NT555 G2s, ive had my car to 156mph at least 5 times now and it feels solid as could be. Only felt floaty one time around 100 mph, that was right after i got these tires on, the shop set them near 40 psi cold and they were like ice skates on a warm road. Since ive set the psi lower, no issues.
Fender5803
New Hampshire
Idgaf about standard market increases. The value is still not matched by anyone else unless you want a 23 Camaro.
This is the exact same guy that went on and on about the active exhaust being pointless and sounding like shit and then went and optioned it on his car...
@SoggyBottomBoy just because it's not in your budget, doesn't mean it's not a good value. Idgaf about standard market increases. The value is still not matched by anyone else unless you want a 23 Camaro. There is enough in the package that differentiates the car and improves handling to make it worth optioning. My original point stands. If you're not going to mod the suspension, and not getting the performance package, don't even try hard turns at speed.
1) Didn't option active exhaust, it is pointless if you plan to do aftermarket, and does sound bad
2) my budget is probably more than your house
3) its objectively a dog shit value, just like the year is as a whole for mustang. I can achieve 100% better results with custom parts for half the price.
[/QUOTE]
Good for you and just go for your after market additions. Glad you know people to do that for you or do you do it yourself ?
Fender5803
New Hampshire
Agreed
IFFV68
Forgot to mention that's a GT Premium, without PP.
After driving F-150’s most of my life my GT Premium took some time to get use to.
The Lane keeping system can throw you off guard if you're not use to it.
Take your time and learn how your new Ride Performs?
