B&O System is garbage
Farmer Fran
Farmer Fran
2024 GT Premium Vert
Farmer Fran
Farmer Fran
Top up or down? Source? How can one replicate? What are the signs?/symptoms?
Its all back in here somewhere
Checking …..
edit: didn’t notice if you noticed any difference between top up or down, although it shouldn’t matter and then need the ‘test’ tune so can see / hear.
the article regarding reduced capacity also mentioned no am but mine has am so not sure if it would be noted on the sticker if it had the reduced capacity
Farmer Fran
Farmer Fran
Checking …..
No noticeable difference with top up or down.
Things i noticed
Center speaker is overpowering in surround or stereo mode
Rear speakers are super mute.
EQ helps but barley and would almost need to be adjusted on ever song to be good. Or at minimum every "album"
Something is very off about the sound.
135Hoser
2024 Dorkhorse, 2024 CR-V
It's much better with a decent sub. Also it requires a lot of volume.
Radiant
East Coast - United States
B&O audio bad or bad hearing??🙄
The system itself is fine, it's just the subwoofer that's "meh". If you're an audiophile you can opt for the 9-speaker system, or an aftermarket subwoofer. Thankfully, it's easy to access the subwoofer in the trunk.
RLE55
38.9967° N, -84.6310° W
Redline Subwoofer arrived today, will get to it soon.
That's my opinion as well. The factory sub is "thumpy". The rest of the system sounds decent. Putting my Pioneer in this weekend.
I haven't installed the Redline yet but I did check the OEM sub with my head beside it. I had a decent song and volume on. I couldn't believe how bad the performance was. It won't take much to make an improvement.
Things i noticed
How does ‘No quarter’ at (volume) 20 do for you?
Farmer Fran
Farmer Fran
I do not own it so can only check on streaming services. But will give it a go.
To be fair, watch for @:47 seconds, there should be a decent punch, 20 may be a tad high.
