Automatic Shift Knobs
james32thedge
From what I remember, it's just the one piece (carbon surround with the boot portion). The hardest part was getting the boot over the new know, had to cut and stretch a little.
Thx so I gather after removing the auto trim and boot part the manual boot just snaps in after putting the boot over the shifter, thx again
bee bop
Temple, GA
Yes you completely remove the trim and boot and replace it with the manual cover.
i forgot to share it here, but i got the Billetworkz titanium shift knob and the manual shift boot and installed them, also anodizing the shift knob. here is the final result
S650 Mustang Automatic Shift Knobs 1738224461946-et
and here was my anodizing setup
S650 Mustang Automatic Shift Knobs 1738224554427-7f
power bank going into a USB-C PD board set to 20V, positive on the bolt the shift knob was threaded onto via aluminum wire, negative on the aluminum sheet that goes into a baking soda and distilled water solution. i used a rotary tool with an abrasive buffing end to remove the shift knob's protective coating first, because otherwise it was just turning an ugly yellow-green
DarkkMatter
Virginia, USA
For an Automatic Shift Knob replacement, I think a Black Horse Head with Red Eyes would look cool.
Probably can 3D print one out of the right material.
On a manual though, having to shift often, that wouldn't be easy on the hands.
shadowmaker
NC
2024 Ecoboost w/performance package
So, I am lil confused on what to order from billetworkz. There are 3 options a $99, a $159, and a $279. Unless I am over looking it, there is no real explanation of the difference. I am assuming the $99 one doesn't have a shift knob. But is that all I need to order other than a knob? What makes the $279 option a $120 more.
james32thedge
Not knowing what your looking at to buy but if your just looking at the knob itself that is probably the lower costs. the higher cost includes the shifter and the knob to change out the factory shifter. The knob itself cannot go on the factory shifter.
shadowmaker
NC
I know the knob cant go on the factory shifter.
Why is the one
https://billetworkz.com/products/the-fusion-weighted-shift-knob-ford-mustang-auto-2015-2024
$120 more than this one?
https://billetworkz.com/products/gl...tang-auto-fitment?_pos=2&_sid=750da105f&_ss=r
And is this one basically an adaptor to put a after market knob on?
Cucurú
DFW Tx.
American Muscle had a white shifter for automatic. I believe it was about 69.95. I believe they also had black or red too. The shifter looked made it look like a 6-speed .
86pagt
2019 Ford Mustang GT
White Madness Garage short shifter and a $35 eBay knob.. worked great on my ‘19 for 60k and removed it before selling… installed on my ‘24 with manual trim.
S650 Mustang Automatic Shift Knobs IMG_2677
james32thedge
Why is the one
maybe the Alcantara leather is the reason. I would contact them they are pretty good at getting back to you. I have the titanium knob that was quite expensive too for a knob but it looks great especially when you change out the trim around the shifter itself to a manual trim without the auto letters
