4500 rpm limiter
Jrws1014
North Carolina
How many miles did you guys have to drive before the 1st gear 4500 rpm limiter stopped activating?
RJV15
Los Angeles
2022 Honda Civic Si
This isnt a corvette man. There is no hard-coded limiter during break-in miles
Lastoutlaw_21
Macon Ga
Ford didn't say there is a hard limiter. But I think there is some limitations with the car until you hit those unknown miles. Do you have a 6m or 10r80?
Have you consistently encountered this? I'm not aware of a limiter operating at that RPM. You're the first I think to raise the issue. Some were questioning the engine rev limiter in the 7000+ RPM range, but that was the expected, factory limiter.
RJV15
Los Angeles
2022 Honda Civic Si
Are you asking if there is one?
Or
Are you asking when yours will go away?
Because there shouldn't be one at all. If you are experiencing one, you might be in limp mode!
In some cars, the dealership has to remove the "valet mode" prior to delivery.
Jrws1014
Jrws1014
North Carolina
It’s definitely there. Car dies out and pops at 4500 rpm
DJGold
Quebec, Canada
Ford Mustang 2015 V6 Manual (3.55 diff)
Maybe with an automatic in park it stops you from revving past 4500rpm?
Jrws1014
Jrws1014
North Carolina
In first gear while driving….manual transmission.
the only limiters there should be are
  • 5000rpm in park/neutral on auto
  • 7250rpm on manual
  • 7500rpm in drive/manual on auto
Jrws1014
Jrws1014
North Carolina
  • 7250rpm on manual
I think it’s a break in type thing to prevent engine damage to be honest
Upacurb
Up a curb at cars and coffee
You would be the first......guys were taking new 24s straight to the dyno.....you need to get your car back to the dealer
no, that is not normal. if you are hitting a 4500rpm limiter while driving, there is an issue and you need to take it to a dealer soon. If your dash is displaying the message "Transport Mode Contact Dealer", you should press the brake pedal 5 times, then the hazard button 4 times, all within 5 seconds. Transport mode puts limits on the vehicle so it's harder to joyride for the non-owners that move it
Jrws1014
Jrws1014
North Carolina
I did not see that message
ThreePedalPlow
Saint Louis
I have a manual 2024 GT Premium Convertible as well. I'm 500 miles in and there was never any kind of limiter in that area. I haven't pushed it past 6,000 rpm yet.
