Which tire size is best? 20x10/11 Wheels
Joe_Cool
Detroit, MI
'24 S650 GT PP, 1984 BMW E23
Hey Folks,
I am in the process of ordering new tires for some 20x10/11 rims that I am putting on my S650 PP. This is the first time I’m installing a set of aftermarket wheels on a vehicle so I want to make sure I get the details right, with the help of those of you who are experienced in this type of stuff. The goal of this wheel setup is to be practical in daily driving applications while still looking aesthetically pleasing. I understand that the term “aesthetically pleasing” can be subjective so to me it means a tire that is low profile yet adequately fills the wheel well both in depth and height.
With that being said I have narrowed my options down to the following; The type of tire without a doubt will be Michelin PS4S as their performance in daily driving applications only compares to the Continental DWS06. I don’t plan on tracking my car or taking it to the drag strip so the PS4S should be more than adequate, Cup 2’s or slicks would be overkill.
Tire sizing is where I am looking for insight, specifically for the rears. I am pretty set on the fronts being 275/30r20 but am split on what I should do for the rears, 315/30r20, 305/30r20, or 305/35r20? I would like the rear tires to be as wide as possible, however based on my research anything over a 315 width either pokes or rubs. I also read that it isn't recommended to install a 315 tire on anything under an 11.5 rim, is this accurate? If that’s the case and we are left with only the 305/30 or 305/35 sizes, which size would be best in relation to the 3% rule and my goals for the setup? Would a 30 sidewall be too small in terms of practicality and affect the ride greatly? Ive referenced a bunch of “tire calculators” and everything checks out in terms of fitment. 305/30 has a -1.8% difference in diameter from stock, 305/35 has a +2.5% difference in diameter from stock, and 315/30 has a -1.1% difference so it seems like I am splitting hairs at this point, but I want to get it right. Long story short I am looking for insight from folks who have had or has wheel setups with a 30 sidewall and if the ride is too harsh/impractical, also if it is possible to fit 315’s on an 11 wide rim. Pics would be appreciated but only if they are the sizes mentioned. Here’s the cliff-notes of my situation:
- 2024 S650 GT Performance Pack – Stock 27” 255/40r19 (F) 27.7” 275/40r19 (R) Pirelli’s (yuck)
- Switching to HRE FF10 rims 20x10 ET35 & 20x11 ET50
- Michelin Pilot Sport 4s tires 275/30r20 fronts
- 315/30r20 305/30r20 or 305/35r20 for the rears?
I appreciate the insight in advance!
agreywolfe
Oklahoma
HRE FF10s 20X10/11 285/35 front 315/35 rear, fitment is flush with minor poke at the bottom
S650 Mustang Which tire size is best? 20x10/11 Wheels 1000001863
S650 Mustang Which tire size is best? 20x10/11 Wheels 1000001862
Project6GR Wheels
Los Angeles, CA
Shelby GT350R
Deleted member 63380
Guest
If I remember, you are not lowered, correct @agreywolfe?
I'm lowered on steeda magneride springs
275/35 20 fronts
305/35 20 rears View attachment 593318
Almost flush, no rubbing
Pretty blue. I wanted that color. None were available. Plus I wanted the California Special blue interior but not the gaudiness of the rims and nostrils. Couldn't get the interior without the Special. Very Pretty. Just picked up the Vapor Blue with blue Brembos for my daughter.
Magic88
Bennington
Thank you, and very lucky daughter!
Guest
She a remarkable girl. Only 22 and a computer whiz of some type. Going to put an SC in hers too. Want one in vapor blue to match her car. But red does scream when you pop that hood.
Tigerchevelle
Tiger2007!
2009 z06 vette,2020 LT1 camaro,LS swapped 72 chevelle,65stang,68vert and coupe,
Hey Folks,
315 tire will be fine on a 10.5 10 wide is possible but has bulging on the tire ,which is not good for handling but ok for just a looks street car
