Iāll give you a call tomorrow. Thanks
Sounds good !Iāll give you a call tomorrow. Thanks
Iām not rubbing.20x11 with a 305 tire is the same height as my GT wheels.
Your 315/35/20 tires are 28.7ā tall. 305/30/20 are 27.2ā. Stock 255/40/19 are 27ā tall. With those aggressive lowering springs thatās why youāre rubbing.
again, thereās tons of people running 20x11 on this forum and Mustang6G. I feel like adjusting your camber properly and running a 305 will be damn flush. Iāve done far too many hours of research on Mustang6G and Iām just trying to save you the time of doing the same
@Project6GR Wheels has multiple threads showing the fitment of their wheels which are the same offset as the HREās unless Iām mistaken but a quick search shows theyāre the same offset.
when you have a minute could you take a picture like the OP does up close to the fender? Would be nice to compare and have for reference! Thanks!I did 11" HRE's with 305s and I think it turned out just fine.
https://www.mustang7g.com/forums/threads/20-hre-ff04s-on-michelin-pilot-super-sports.159671/
āwhatās your rear camber? It looks great. I wonder if my wheels are the wrong offset. Youāre not running anywhere near as much camber as I am and it looks perfect to me. Maybe itās my car?Wheels are 10" wide ET35 (f), 11" wide ET50 (r);
tires 275/35 (f), 305/30 (r)
āI donāt see any poke. I hate any poke. About as much as I hate too much negative camber. LolI've made no suspension modifications. The camber is at factory settings. Glad you like you it, I think it looks good. Honestly, there is just a touch of poke.
You are right.This is definitely a you problem and not an HRE problem.
stop blaming the vendor. And your camber isnāt anywhere near bad nor making it look slammed lol. you bought an 11ā wheel and didnāt think you would need negative camber. Thatās definitely on you and nobody else.You are right.
Itās definitely my problem. Iām the dumb ass who gave $4,300 to one of the venders on this site thinking the wheels would fit flush without running so much negative rear camber. They should have warned me. But thatās on me.
I learned my lesson and now I know to look for a 53ET rear wheel. I just hope others will read this and know what they are buying before spending $4,300. If they are fine with poke, go for it. If they are fine with the look and performance of -2.7 rear camber, go for it. But if they expect a flush fit without changing the factory camber, they shouldnāt buy these rear wheels.
As for me, itās not a big deal in the long run. Iāll just buy some other wheels when I figure out what will fit properly and sell these to the first person who gives me a couple of bucks and move on. Itās not about the money to me. Itās about the time Iāve spent doing an alignment, emailing Vibe asking for help with a solution, and mounting tires. Iāve spent 3 days doing the wheels/tires and two alignments.
There is no doubt many people will be fine running 50ET rear offset. Look how many people run 25mm spacers and like the poke. I absolutely, positively HATE any poke. It looks cheap to me. You donāt see any nice car come from the factory with āpokeā. As for running aggressive negative camber, itās better than poke. But I still donāt like that slammed look. Iād rather have a flush look. But thatās just me. Again, people like different things. Thatās why these cars are fun to mod.
Running a 11" wheel has nothing to do with needing to run an excessive amount of camber. That IMO is a lot of camber even for a street set-up.stop blaming the vendor. And your camber isnāt anywhere near bad nor making it look slammed lol. you bought an 11ā wheel and didnāt think you would need negative camber. Thatās definitely on you and nobody else.
Velgens fit perfect. They have lots of pictures showing this.Someone Explain to me what the OP means by HT53 etc? im fixing to order 20x10 and 20x11 Velgen wheels to put on 285/35R20 and 305/30R20, just curious. I don't mind a slight camber or anything like that. will also be lowered on steeda progressives
