S650 Weight
subarashi-650
Earth
My modded s650 performance pack 10r80 Magneride full fuel tank weighed =
3720lbs
My buddys stock base s650 10r80 300a full fuel tank weighed =
3750lbs
on the same scale..
which is really bizarre because we almost weigh the same after all these mods. I plan to shed some more weight of the vehicle and would like to know more about the differences between those car specs.
I know the pp cars got more weight in:
- front 6 piston and 4 rear piston brakes
- Heavier pp wheels
- Strut tower & K braces.
- Heavier front and rear sway bars.
- Magneride (optional)
What else?…
Oil cooler, larger radiator, front splitter, rear spoiler, air deflectors, drift brake.
But you will save some weight because the GT emblem in the rear on the Performance Pack is lighter than the non-performance pack emblem because of the engraved "Performance" text.
subarashi-650
Earth
Oil cooler, front splitter, rear spoiler, air deflectors, drift brake.
Hahaha you ain’t wrong
8915GT
The factory exhaust is pretty heavy, how much does your full exhaust weigh compared to the stock exhaust?
Deleted member 63243
Guest
My Dark Horse weighs 3950 with a quarter tank of gas. It has Steeda jacking rails, rear progressive springs which are a little heavier than the stock springs, Stop the Hop kit with subframe brace and 19x10, 19x11 wheels with 275 & 295/35 tires.
S650 Mustang S650 Weight 20250422_144710
subarashi-650
Earth
I weighed the stock suitcase resonator and it was 7 lbs heavier than the aftermarket H pipe. I didn’t weigh the Kooks cattless LTH but I assume it’s way lighter than the catted stock shorties.
subarashi-650
Earth
Warlords650
tampa,fl
2024 vapor blue GT
Whats all you did for weight reduction? Mine with mods weigh 3900 with half a tank
Alan Applegate
Roswell, NM
Actually weighing a vehicle with driver in the car is the correct way to do it. I drive a 2024 Eco-Boost Premium, and the advertised curb weight (supposedly wet with all fluids?) is 3,512. It actually weighs 3,525. With me in it, 3,690.
The above mentioned weights are close as the advertised curb weight for a GT automatic is 3,752. I've only seen one weight figure got a GT, and it was a 2025. Without the driver, it was just shy of 3,800 but I don't remember the exact amount. Seems like no two Mustangs are the same.
Alan Applegate
Roswell, NM
A lot of the weight difference seen here is the fuel load. Gas weighs just over 6 pounds per gallon. With the tank size 18 and a fraction gallons, that is about 110 pounds.
ChitownStang
Chicago, North Shore
2015 Mustang GT Premium
16 gallon tank
