did my break-in oil change at 1168 miles. getting to the oil filter is next level stupid, you need to take out about 20 7mm bolts, 4 push pins, plus remove the underbody aero bits, and drop the front undertray. if you drained the oil before dropping the tray, there will be oil on top of the tray, but the good thing is the tray itself is made of some fiber material and it absorbs barely any, if any at all. sadly, it will quickly absorb brake cleaner + oil, so don't make the same mistake i did. the oil filter is still mounted horribly at a 45 degree angle and is right behind the alternator, plus the oil that drips from the filter will fall onto a crossmember for the front subframe. i am certain that Ford did not think about oil changes
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
got to get a good look at my clearances on my wheels today, and boy are they close
front:
rear:
Geez Thats close! But still good to go!
Smaaron
Tucson
2015 Honda Accord
I’m leaning more and more towards using my free dealer maintenance plan for oil changes. All this plus disposing of 10qts of oil sounds like a PITA!
sdsteele2
Tennessee
24 Mustang GT
It’s definitely a PITA. I was able to stuff a bunch of pig mat in after removing the drivers side wheel and slide my form-a-funnel into the small opening. No way anyone working flat rate would take the time I did to make sure there was no mess.
fun little fact: if i wasn't able to get a Dark Horse, a GT would've been my backup option.
S650 Mustang roket's Dark Horse - "Azureus" Project 1695998320648
S650 Mustang roket's Dark Horse - "Azureus" Project 1695998350090
S650 Mustang roket's Dark Horse - "Azureus" Project 1695998411279
401A, yellow splash, performance pack, nite pony, black and grey stripes, magneride, active exhaust, grabber blue calipers, and space grey interior. it would've been named either "Stinger" or "Thunderstruck"
planning on getting some parts of Azureus wrapped gloss black eventually. here's a really rough idea of what i had in mind
S650 Mustang roket's Dark Horse - "Azureus" Project 1696730653426
again, it's a really rough picture but it gets the idea across. under the headlights, roof, antenna, and that triangular area along the side
last Sunday i did my first ever autocross event. SCCA AZ Solo. due to the tires, i was in Super Street Prepared with a Corvette Z06, Porsche 911 GT3RS, and Porsche Cayman GT4. i ended up only a couple seconds slower than the GT4 and even less time slower than the GT3RS. the accelerometer says i pulled a max of 1.16g lateral, 0.88g braking, and 0.72g accelerating during the whole event
was looking at the wiring diagram for the reverse lights, as i liked the diode dynamics 4th brake light kit for the 2015-2023, and Ford has changed it quite a bit. there are now 2 reverse lights and 3 pins on the connectors, all used. for some reason each reverse light has it's own power instead of having shared power. pin 1 is the right reverse light, pin 3 is the left reverse light, and pin 2 is ground
i was looking through the workshop manual to see how Ford says to remove the exhaust manifolds and i'm really confused why the driver's side manifold looks like this???
S650 Mustang roket's Dark Horse - "Azureus" Project 1699350973801
also Ford says to basically pick up the engine to do exhaust manifolds
S650 Mustang roket's Dark Horse - "Azureus" Project 1699351067994
Ford Motor Company
Official Ford Account
Dearborn, MI
Ford Mustang
We can't wait to see the final product!
found some pictures of my Dark Horse at the autocross events i've been going to. thanks to Jason J on the AZSolo forums for these
11/5/23 - my 3rd autocross event
S650 Mustang roket's Dark Horse - "Azureus" Project 1699428011429
S650 Mustang roket's Dark Horse - "Azureus" Project 1699428032073
10/15/23 - my 1st autocross event
S650 Mustang roket's Dark Horse - "Azureus" Project 1699428400641
S650 Mustang roket's Dark Horse - "Azureus" Project 1699428920003
S650 Mustang roket's Dark Horse - "Azureus" Project 1699428655392
S650 Mustang roket's Dark Horse - "Azureus" Project 1699428704992
S650 Mustang roket's Dark Horse - "Azureus" Project 1699428754335
wilkinda65
Sun City Center, FL
BEST color on a DarkHorse 😍
JAL
Gatineau Hills, QC
2019 Mustang GT
this thread is inspired by the one DannyJ7 made for his EcoBoost, a place where i will keep things updated on my Dark Horse, including anything i modify on it. I always have specs and production process with dates in my signature
the project is called Azureus, because the car is blue
Current plans for mods:
You've got 325s in the front!!!
Can I see pics of how they fit please?
Thanks!
Reactions: JAL
