Remove Active Grille Shutters?
bbowes9
2024 Shadow Black Mustang GT Premium A10
Hey all, new to the s650 platform , coming from s550. I've had the car just under 3 weeks, and unfortunately with my luck a deer came running out right in front of me and I hit the poor thing. Thankfully got video of it but that's irrelevant.
Anyways, checking the damage out the past few days it only damaged the front bumper slightly and the grille+active Grille Shutters, no other damage anywhere. I am now having a check engine light which I've confirmed is from the shutters. That brings me to the main question: Is there any way to disable this with Forscan or anything or get rid of the check engine another way? I have a new bumper coming in soon and I'd like to remove the shutters if possible. It is not a big deal if i'm not able to. Thanks in advance!
GrabberB
I cannot help you with the Forscan question but will offer up another potential solution with some caveats (damage wise). Did the accident (deer) only damage the shutters not the housing or surround? If the surround is fine the easiest thing to do is remove the shutters and leave the actuator connected. Again this assumes that part wasn't damaged. Basically, what I saying is the actuator would still work but move nothing i.e. still wired up.
The shutter themselves are very easy to remove. Again the rest of the system would need to be still intact to clear the DTC.
To help you better understand what I'm saying check out the Whipple instructions for non-performance pack GT. The shutters get removed as part of the install. Further you can check out a YouTube video from Murphy's Law Garage (Whipple Stage 1 install) where he shows the process of removing the shutters but still leaves the actuator connected because the Whipple instructions were unclear whether to reconnect. He reconnected to avoid a possible DTC. More than likely Whipple/Ford covered this is with their programming but who knows.
bbowes9
bbowes9
I see, sadly the surrounding was damaged in the process. But that gives me something to look on if I can get a replacement part. I appreciate that a bunch!
GrabberB
You'll need to replace the surrounding damaged part. It serves a couple functions that being directing airflow and support. No way around needing to replace this.
bbowes9
bbowes9
Good to know, I’ll look for a replacement in that case!
Just remove and unplug … all the Whipple cars did.
bbowes9
bbowes9
From what I’ve tested unplugging seems to not do anything, but I also haven’t tested that enough. I’ll test again and report back just out of curiosity. I can also post pics of the damage if needed.
Billycar11
i would take all the slats out so the motor can turn freely and leave it plugged and and see if it works after that and code goes away
a few whipple install guides have how to remove them
bbowes9
bbowes9
Will try this next, just confirmed unplugging does nothing and will cause the code to come back just for anyone curious.
bbowes9
bbowes9
For anyone wondering now or in the future, the answer is no. You aren't able to take off the shutter blades. It will end up throwing the code because it tries to detect an minimum/maximum threshold. I was able to get new parts in and put the blades back in after that experiment and no codes have showed up.
Billycar11
so probably only one blade is needed? to fool it even if most or some are broken just so it can detect it
bbowes9
bbowes9
That would be my guess, I never did try that but I’d assume you’d just need the one that goes in the motor. I may try it just out of curiosity when I get the bumper in.
