scainerrt
Morgantown,WV
2024 Mustang Dark Horse
Had a look under the hood. The recall says behind the dash.
I did see one retainer for the clutch hose. It's a plastic retainer at the end of a stud.
It's holding at the tip of the stud.
I was able to squeeze my arm down there but can't push it further on the post. Looks secure though.
I did the same thing and it appears that it doesn't go all the way onto the threaded bolt stud. I tried pushing my on some more but it didn't move so I would say it's fine. I'll find out Monday morning when I take my car in to have it looked at.
DCS
Ocala, FL
Yeah, I'm in the club too. I have an appointment for Monday, but if that picture is what we need to look at, I may just check mine and cancel if all is good. Ford said they would need my car all day because their tech is too busy right now.
My dealer said the same thing about needing the car "all day". Probably to let the engine cool.
BrianJ77
I just checked mine. All secure. I'll wait until the techs on my area to have seen several of these before I go down there to the dealership and sit for a few hours. Looks like there's no real issue from what I see on mine and all y'all's. Those going in next week please post the results and if they even had to fix anything. TIA.
samson
Great information on this thread. I'm going to check mine. If it looks good I'll just wait until my first oil change to have it done.
Unixis
San Francisco, CA
2024 Mustang GT Prem + PP w/ 6spd
Howdy all. Whelp... guess I may be one of the "affected" ones. This is what I think they're looking for:
Area Looking (right behind driver's firewall):
S650 Mustang Recall 24S36 - Leaking Hydraulic Clutch Pressure Line 1717694400442-7k
Suspected problem child:
S650 Mustang Recall 24S36 - Leaking Hydraulic Clutch Pressure Line 1717694671633-cg
For those that are curious: mine was mfg in 06/23 - 401A GT PP
I have my recall service appointment scheduled for first thing tomorrow.
infinitemberstang
CA
Dark Horse - Blue Ember - MT
^^ thanks for that info matey.! So helpful this thread! Love it!
I followed the line as below:
S650 Mustang Recall 24S36 - Leaking Hydraulic Clutch Pressure Line IMG_3476
which leads to the insulated line fixed to the stud close to the firewall and it is secured
S650 Mustang Recall 24S36 - Leaking Hydraulic Clutch Pressure Line IMG_3477
checked for wiggle, pushed it to verify it’s in place and it’s looking good.
I might cancel the appointment with the dealer and wait for a bit and see what everybody else is reporting here.
@roket - would be able to shed more details on this recall?
Thank you all for the support and pics here - so helpful!
my dealer has not gotten one in for this recall, but i recommend still going to the dealer so the recall itself can be closed, as Ford probaby has you vehicle flagged in OASIS as with an open recall
infinitemberstang
CA
Understood - thanks for the inputs. I just want to make sure that the techs at my dealer don’t eff anything else up.
Will take it to make sure whatever needs to be closed in relation to the recall is taken care of. Thanks for the response.
DCS
Ocala, FL
Based on the pictures, mine is secure.
BrianJ77
What is OASIS and what does it mean for my car if I leave the recall open for, say, 6 months?
OASIS Is the system that Ford dealerships used to check a vehicle for things such as factory warranties, Ford extended warranties, connected vehicle data and recalls. Leaving a recall open will not really do anything. So in theory, you could just leave it open and there would be no consequences
WayneK
WI
If I were you I would push it on the stud now. Just check to see that the line hasn't made contact with the exhaust manifold which would require replacement of the line.
Dxm
San Antonio
Hey gang. This is what I see. Does this look right? Do I even need to bother bringing the car in? Or wait till my next oil change in December? Thanks!!
S650 Mustang Recall 24S36 - Leaking Hydraulic Clutch Pressure Line recall
Unixis
San Francisco, CA
I'm of two minds on that...
Mind 1: The tech that sees it off the post may be more inclined to do more inspection down the line if they see that I'm in the "affected" group vs just a "thumbs up". Good news is the dealership is like 8 mi away from me so it won't be cherry red by then (and it's been plenty warm enough before now to cause issues, so I'm just lucky at this point too).
Mind 2: On the other hand I also know it's an easy "fix" and I know I'm now in an "At Risk" group...
If my appointment wasn't first thing tomorrow without me having to drive till then I'd fix it immediately. (Edit: Oh and... the fire extinguisher's going along for that ride too... if the clutch gives the entire area's getting doused, lol)
