Need help with alignment settings for my DH without handling pack for autox and street
Kujyy
Utah
So I bought:
Steeda Mustang Trident Gloss Titanium Square HPDE Wheel Package - 19x11 and the 25 mm spacer for the front
Steeda Mustang Camber Plates All
Steeda Mustang MagneRide Dual Rate Ultimate Handling Lowering Springs
as well as re-71rs 305/35 19 inch tires it is a square set up
I am trying to figure out where to put the alignment for both autocross and street use. Note I work from home so I don't drive a lot anyway but there are times where I will have to. I will be using the wheels and tires that came with the car for the street and using the above setup for autox. I know its not ideal to try and set it up for both as it won't be optimal for either but I don't have much of a choice as it is my daily. I want to be as aggressive as I can with out destroying my street tire. Any suggestions or recommendations would be appreciated. I also may have put this in the wrong area by accident so please ignore will be reposting in proper section.
Update: I ended up going with -2 camber and 0 toe I have autox in two weeks will update then and let you know how it goes.
Flyingtexan
Giddings, Texas
2025 Ford Mustang PP, 2022 Camaro SS 1LE, 2023 RAV4, 2006 Caddy CTS-V
Following
