Maybe a future recall
danny58612
s650 EB
Has anyone experienced this on a 2024-2026 Mustang EcoBoost?
This has only happened once, but it has me concerned.
After driving normally for about 40-50 miles, I did a full-throttle pull on an open road. As the car reached around 79-80 mph, it suddenly stopped accelerating. The accelerator pedal was fully to the floor, but the transmission upshifted and the car would not go any faster than about 80 mph.
There were no warning lights, no messages, and all engine/coolant/transmission temperatures were normal. I pulled over, shut the car off for about 30 seconds, restarted it twice, and the issue was still there. Then I parked for about 15 minutes, restarted the car, and everything was back to normal. It has not happened since.
I scanned the car with FORScan afterward, and there were no DTCs or pending codes.
One thing I also noticed shortly before this happened was that cruise control would not let me increase the set speed above 80 mph. The speed limiter feature was not enabled, and I verified that wasn’t the issue.
Has anyone else experienced something similar? If so:
* What ended up causing it?
* Did the dealer find anything?
* Were there any software updates or module replacements that fixed it?
I also have a video of the incident if that helps compare symptoms.
John S
Novi, Michigan
2022 Mustang Mach 1
One of my MagneRide connectors on my Mach 1 had a fault and I got a dash warning that top speed was limited to 80mph. No codes, just a warning. Did you get any kind of unusual dash warning, maybe something intermittent? Electronic glitches can be soooooo frustrating.
danny58612
s650 EB
No. Same system just engine it can hypothetically happen to gtd or eco
Sounds like speed and cruise setting nannies are on in the infotainment. Go in there and shut everything off.
Maybe so but it seems you have zero sense of humor. Guess its OK when you make snide comments. It must be the AZ heat getting to you.😎
Wet bcm?
I had a similar issue on day one with my car... turned out to be the speed limiter was on... turned it off and nearly three years later, never happened again!
Blatantly flaming someone for not having a GT when they are asking a legitimate question has nothing to do with my sense of humor friend.
MyKey ? They can be programmed with a hard limit. Seems unlikely if a restart "fixed" it.
Any recent work on the car? Mods? Maintenance? Repairs? A bmw owner looked at the wrong way?
You might be on to something with the MyKey suggestion. OP were you using a second key fob when this happened?
@AZ_Ryan The OP didn't seem to take it the way you did. There where several others didn't as well. There is a difference between a flame and a joke. Guess you seem to want to have the last word. That sometimes make you seem arrogant and condescending.
I dont know. Bashing a guy's car seems a lot more arrogant and condescending to me. But as long as you thought it was funny and the OP didn't it respond then I what do I know.
