Low cost Center Dash and Sub Woofer speaker upgrades = best $110 you'll spend on your Stang
Cobrakit
Southern Maryland
2019 Mustang GT PREMIUM PP1
I used the orginal trim ring, but with the grill. Also, the Pioneer bolt holes line up better than Redline. With Pioneer, I was able to use stock holes by just longating holes. With Redline, only 2 line up, other 6 have to be drilled into box in new location.
RetiredGTdoc
TX
2026 Mustang GT
Couple of questions:
1) For those of you who initially used the Pioneer 10 in and then switched to a more sensitive speaker, did you notice a difference in sub volume?
2) Sofa King, Where did you get the spacer ring? Which product?
Thanks!
jawsr101
lexington SC
2024 mustang GT
How are you guys getting the ring off without out breaking the tabs?
Cobrakit
Southern Maryland
I would guess that as carrful as you can be, that some number of pins will break. If you push the pin from the side, it should release the trim ring easier. If your not going to reuse the stock grill, it doesn't matter. I located the trim ring on the speaker with double sided tape and then the metal grill screws over top of it.
Thanks!
Amazon (where else? Lol)
https://a.co/d/06mXkisE
Starship Enterprise
MD
2025 Mustang GT Premium
Thanks!
I replaced the Pioneer with the Hifonics.
The improvement was massive and very noticable. Don't expect a huge thump because the amp can only do so much, but there was MUCH more there than with the stock sub and the Pioneer.
It is well worth it and only took 15 minutes and $49.
jeetee
Those of you who did the upgrade - do you ever wish you would've went the full aftermarket sub in an pre-fab enclosure route instead?
This setup is super enticing, especially given the price and ease, but I'm a bit apprehensive that I will do the upgrade and still long for a little more "bump" (nothing crazy like 600W+, but more so maybe what a 300W RMS speaker would give out to still keep the other speakers stock)
RetiredGTdoc
TX
2026 Mustang GT
I got my "retirement" Mustang so I could have fun and tinker with it. Even though the Pioneer sub really cleans up the B&O audio, most of this is because it doesn't produce a very muddy harmonic at the car's resonant frequency and allows you to turn up the bass for the door and rear shelf woofers. Although I can hear the Pioneer, it's not really punching as hard as I would like. I am contemplating switching out to a more sensitive subwoofer like Starship. I'll let you know how it goes.
Starship Enterprise
MD
GTdoc: Do it, you won't regret the extra $49 and 15 minutes to swap out to the Hifonics sub.
The only reason I got the Pioneer last year was so many here did it and said it was great. It was an improvement in quality, but it had zero presence. Could barely hear it.
My hunch said 1300W (Pioneer) is way too much when the amp is only 100W allocated to the sub. I tried a better wattage match and the improvement was massive.
If using the stock amp... filling the Pioneer with sound was like filling a bathtub with an eye dropper.
