Knock noise on start Mustang GT 2024 Performance
GrabberB
So what is the solution?
Not sure there is a solution based on the number of threads I've seen on this subject. I will say the audio in your video is louder than others I've listened to. In other words, your audio captured the sound so well it could be deceiving to the listener. Usually, it's the opposite and the "knock" is not as loud. I contribute the latter to pour audio when recording.
I don't think it will take long for other members to chime who may have more insight on this subject than I can provide.
Just wanted to let you know you're not alone in this issue. I believe most have been told while alarming there is nothing to worry about.
I'll second what GrabThatBlue said about going to another Ford Service Dept. There is no reason why they should not be able to ID the cause. Not saying there is a solution - At the very least they should be able to describe the cause and ease your concern.
sherif.elshamy
Dubai
ford mustang 2024 gt performance
That sound comes like on time every 5 or 6 starts with no specific timing so every time i go there they start the car it starts normally so they don’t know why sometimes it do that
I let the car for them but everytime i take the car and the report the car didn’t show the sound
So i hope if anyone see same issue and identify it to tell me even to tell them to check
sherif.elshamy
Dubai
Knock knock? Who’s there?
Sorry, couldn’t resist lol.
I would take it to a different dealer for analysis.
I’m in UAE we have only one registered dealer for ford i have no options only them
brian5814
fl
2025 gt premium performance package manual vapor blue night pony package
Good luck that knock would drive me crazy also,
sherif.elshamy
Dubai
Thanks
The most annoying thing that this noise appeared after only 4 days of buying the car
And every time it goes to dealer and it back with the same issue as they don’t know
GT-24
Carbonized Grey,401A,Active Exhaust, Brembo,Auto
Would possibly using a vehicle stethoscope as a probe help to isolate the area of the sound ?
sherif.elshamy
Dubai
The knock be just one time when start one knock aggressive one then everything goes normally
And this knock comes only when the car is warm and maybe every 5 6 times of start the car comes one time
If you can get under the car, try and isolate where the noise is coming from. Ie, engine, trans etc. I doubt it would be from the rear
A.alansari
Qatar
Mustang GT 2024 PP
a guy I know who have the same problem told me don't put the gear on N then use hand break then push the gear to P
instead put the gear on P first then use the hand break maybe try it and see what happens
sherif.elshamy
Dubai
بما انك في الامارات احب اخبرك ان كان عندي نفس السيارة وبعتها بسبب نفس المشكلة وبعض المشاكل في السوفتوير ، بخصوص مشكلتك مالها حل وحسب كلام الوكالة انهم تواصلوا مع المصنع لمدة ثلاثة اشهر وتوصلوا لنتيجة ان الصوت طبيعي ولا مشكلة فيه ولا خطورة على السيارة او المحرك وناقل الحركة ، اتمنى اكون افدتك .
والله افدتني انا والله السياره عند الوكيل اكتر من اسبوعين وماحد بيفدني سبب المشكله او حلها وفي النهايه بدلوا ال starter ونفس المشكله موجوده
Mustang GT 2024
Follow this...
After driving the car
Move shifter from D To N wait 1 sec
N to R wait for 3 secs
and then apply E brakes and put in P
Trust me This will work!
I had same issue and after following this i dont get it.
I'm just guessing here, but it sounds like the gearbox output shaft has a little play in the splines.
Cipis
czech republic
Follow this...
Yes, this works!!
