GhastlyTT
- Joined
- Mar 18, 2024
- Threads
- 14
- Messages
- 305
- Reaction score
- 449
- Location
- Hampton, VA
- Vehicle(s)
- '24 Dark Horse, '25 F-150, '23 Mach-E GT, '24 R1250GSA, '17 S1000RR
They'd siphon water inward instead of outward?
Ok, this...Reread my post title
So, hypothetically, do you have a specific reason you want to run tires in the opposite direction from what they are designed for? Put simply, they perform better when installed as designed.
Helping you hydroplane better?They'd siphon water inward instead of outward?
You didn’t answer my questionSo, hypothetically, do you have a specific reason you want to run tires in the opposite direction from what they are designed for? Put simply, they perform better when installed as designed.
was just trying to have a technical discussion but it appears this forum is more about fluff discussionsNot sure what else you are looking for... We "hypothesized" that the traction could be less.
Did you ask the Mfg. yet?
In the name of science, try it out!
In my case I was merely having fun. I cannot have that technical discussion with you because I do not know very much about tire design and know absolutely nothing about this particular aspect of tire design.was just trying to have a technical discussion but it appears this forum is more about fluff discussions
Not sure how technical we could get... most of us are not tire scientists. Were you looking or discussion on molecular composition or friction coefficients or what exactly? I think that we covered the fact that the grip is likely to be less than optimal and it could even be a danger if it does indeed increase the risk of hydroplaning etc... about as technical as I get on the subject... sorry.was just trying to have a technical discussion but it appears this forum is more about fluff discussions
GTKIf there is one thing I cannot stand, it is ignoramuses acting like they know something when they know nothing about it. They sure post their AI search results with utter confidence, though, which creates a vicious circle. AI picks up BS, repeats it, so the ignoramus posts it, reinforcing the AI to repeat the same BS on future searches.
The reality is that most of us are going to have no idea about the answer to your question.
