Gauge Detail - What is normal?
Achlys
KC Metro
I searched without success.
Within the gauge detail screen it shows various temperatures, pressures of vital parts. Seems like a reasonable screen to watch at random times or if romping the machine with smiles. What is normal? What could be considered an average range? What if Murphy just popped into the backseat and decided to F with your Mustang? When should the oh S meter go off?
Thanks for your input.
After I posted this question another post popped. Apologize for the duplicate!😞
D/\rK•650
2025 Mustang DarkHorse
So which gauge details are you looking for information on? There are more than a couple. Oil temp? Transmission temp? Air intake temp?
I keep an eye on head, oil and trans temps. Normal can vary a bit with options. I believe I saw "normal" range in my 2024 GT manual. I have not looked at any up-dates for my 2026 GT. You can find the manuals easy online.
It all depends on what you are doing with the car. I wouldn't be concerned with any of it on a daily driver.
If you are on the track, or driving hard in the back roads, or doing some hard pulls, then keep an eye on your oil, trans, and head temps.
What is normal and what is not has been a subject of great debate in multiple threads here. Sometimes having those gauges in your face causes people to over think and worry unnecessary. Also note that PP and DH cars have auxiliary oil and trans coolers that further muddy the waters.
Without getting into the weeds on each thing individually, I would recommend you turn on your track gauges on the infotainment screen and take note of the blue, yellow, and red areas and then compare those to the actual numbers on the dash.
Also keep in mind that Ford programs these cars to give warnings and will even go into limp mode as a fail safe if temps exceed manufacturer programming.
S650 Mustang Gauge Detail - What is normal? 17866
Red is bad, yellow is warning and anything else is just waiting to get there.
Achlys
Achlys
KC Metro
Mine is just the standard GT premium 401a with 355 rear end non-PP. I understand white, yellow, red, and limp mode. Just interested in what is normal. It seems on other threads a discussion about temps etc. that are varied. If I was tracking the car having these gauges active makes sense, as a daily driver it could be a mind game. Just curiosity on my part.
Snakebyte
West Central FL
Mustang, Fusion
I miss the increment numbers we had on gauges years ago.
With new cars, manufacturers prioritize being able to select multiple gauge configurations and cool graphics over tangible data display. It's a significant step backward from my perspective that increment numbering has gone. Sure the different colors look nice, but as a driver that pays attention to gauge variances that may indicate negative earlier, I'm personally not impressed.
tlr3715
New York
2017 Mustang GT
On my s550 one of the plastic pieces developed a hole in the intake. Noticed the vacuum gauge wasn’t behaving the way it normally does. Usually spikes then settles after on throttle. It was just flipping all over the place.
5 different people are going to give 5 separate opinions on whats "normal". There are guys on this Forum that think any oil temp above 200⁰ is hot, which is silly. The yellow area of the gauge starts at 265⁰ which should tell you what Ford thinks. There is data online that says anything up to 240⁰ is normal. The reality is "Normal" depends on how you're driving the car and ambient temps. It will fluctuate greatly depending on how hard you get on the pedal.
I have the same spec car as you and I live in Arizona. My oil temps live in the 215-220⁰ range when fully warmed up under normal driving. Trans temps are usually around 200ish. Heads temps usually stay around 200⁰ or just below. My experience is that during spirited driving temps will go up but fall back down pretty quickly when you back off.
My advice is to drive your car and enjoy it. These cars don't have any inherent over heating issues unless you beat on em. The only exceptions are if you're tracking the car or Super charging it. If so, then get an auxiliary oil cooler or buy a PP car. Otherwise try not to go down the rabbit hole and over think it. 👍🏻
I should also mention that running your AC actually improves the cars operating temps due to the higher fan speed. It seems counter intuitive, but I can confirm its a thing.
Neggytive
Aluminum has good heat transfer properties so as long as your radiator, fans,hoses and coolers are in good shape and air flow is not blocked the heat in the engine is going to transfer thru various fluids and be dissipated in the coolers as air flows over them.
The head temp can be 50 degrees over the engine coolant temp and still be fine.
Look at how hot an air cooled Harley head gets without the benefit of anything but air flow cooling the head and oil carrying away heat to the cooler if so equipped
Jimbo33
Rochester
2024 Mustang GT conv
2024 GT conv. I like the readout in the main screen between the speedometer and the tach. I understand that is useless information but I like it because it brings me back to my 60's muscle cars when full instrumentation was standard and useful as those cars were not reliable. I tried selecting the gauges in the right hand screen but I found it useless even for nostalgia as It has no numbers!! It is just a dial on a gauge readout which conveys no useful information. I understand that Forescan can correct that and I am looking into it.
Achlys
Achlys
KC Metro
I mean you could have said the same thing in 1966. I was eight, and my parents thought the world was ending. Then again, my dad was born in 1910, he went through the depression, and two world wars, the Korean War, etc. I grew up old school. 🤔
What is normal in 2026?
