Forscan - activate the shift light indicator
Dexter1924
Alabama
2024 S650 perfomance pack
I have a 2024 s650 performance pack. I know that some 10 speed s650s have hidden away the shift light indicator in the software. Is the shift light indicator only on s650 cars newer than 24? I want to activate the shift light indicator but in my research ive found that some have it and some dont.
Dexter1924
Alabama
is it possible to use Forscan with a MacBook Pro running an M1 chip?
nultyyy
Los Angeles, CA
2025 Mustang Ecoboost
To run it on MacBook you’d have to install a virtual machine of Windows on the Mac since Forscan is primarily made to run on Windows. Overall it is doable via Parallels, but it’s all kind of tedious.
(I’d recommend a windows though.
Dexter1924
Alabama
gotcha ok thank you. I am gonna have to figure out the parallels work since I only have a MacBook laptop
Dexter1924
Alabama
would it be at all possible to run this on an android device using a bluetooth obd plug
SS2 GOTZ
Denver, NC
2024Mustang GT Performance Convertible
"To run it on MacBook you’d have to install a virtual machine of Windows on the Mac since Forscan is primarily made to run on Windows. Overall it is doable via Parallels, but it’s all kind of tedious."
I was able to to run it on my Macbook pro M1 using "Wine Stable" as an intermediary, googled it and found a quick and easy video, all free. I updated the speedometer display, added shift indicator, added external temp warning, and enabled walk away locks. Haven't used it in a while since several OS upgrades though. Definitely hard wire the connection for stability, lots of examples of people having problems with bluetooth connections.
Dexter1924
Alabama
Thank you for the info on that, I'll have to see if I can find the "Wine Stable" that you mention. It might be tedious but for now thats the only option I have.
krisk
Here is my solution. Cartek OBD2 Shift Light. It works great!
ZXMustang
tooner
2025 ESS G3 Mustang GT
My 26 has this in the radio under the performance apps. 10 speed car.
