Ford Performance Catch Cans
hoodscoops
NY
DH, Sti
Why does it come with 2 catch cans now from Ford Performance? Is it due to the dual throttle bodies? The S550 / GT350 came with the passenger side.
Alan Applegate
Roswell, NM
No. There are two banks of cylinders hence two cans. Most of what is captured is in the form of water and volatile vapors which appear in both banks. Using just one can is done in some cases, but it isn't the most efficient way.
Jonyxz
San Juan, PR
2019 5.0 401A 10R80
I installed both but only passenger side catches oil as its connected after TB(vacuum). After an oil change interval the driver side was clean so I proceeded to remove it. Prefer having easier access to dipstick than a useless canister.
Farmer Fran
2024 GT Premium Vert
Why is it that you need one, yet it is not supplied from the factory?
JimC
Howell, MI
Because Ford (and all manufacturers) can take care of the issue by routing the vapors to the intake to be burned off and meet air quality standards. Since many people have a difficult time doing minor maintenance, they know that the average owner will never empty the catch can if they installed them at the factory so the car wouldn't meet air quality standards in a short time. Then the fines would be assessed against the manufacturer for the fleet not meeting the standard.
So the easiest way is not to do the catch can and route it to the intake and burn off the vapors.
Steve@Lethal
Wellington, FL
18 Saleen Yellow Label
So the motors are still the same as prior years with the PCV. It pulls air from the driver side into the motor and out the passenger side. The drive side will mostly stay dry unless you have a lot of blow-by. Doesn't hurt to have though.
https://www.lethalperformance.com/s...il-separators-and-catch-cans?manufacturer=991
Steve@Lethal
Wellington, FL
Simple answer. It's illegal to have fuel and oil mixture to be stored outside of a motor so it's an EPA thing. This is why on some of Fords manuals, they suggest you add one as they can't new.
So the open breathers I ran in the 80s and 90s, and the hose down to the header to draft vacuum from the valve cover breather as some ran, probably are a no go from the factory by Ford? :shock:
It's not the fuel/oil mix but the crankcase gases (leftovers from engine combustion) that aren't staying in the engine. The whole emissions thing...
Frogdog1
Dixie
The EPA is......you fill in the blank. "has too many employees making up things to do."
Jonyxz
San Juan, PR
2019 5.0 401A 10R80
Actually, using the engine vacuum to pull out excess gasses from the crankcase is one of the few bright things the government did. Not only for the environment but for our engines longevity too.
