Electric drift handbrake retrofit?
Mulletdaddee72
DFW
Hello, I'm currently in the market for a s650 GT to use for daily and occasional drift use. I would like to get a base model for the smaller brakes so I can run 18's mainly due to drift tire sizes/availability/cost but I really don't love that I have to get a Performance pack to get the electronic drift brake so I'm wondering if anyone knows what part numbers I would need for the retrofit and if it would be possible to use FORSCAN to update the infotainment sys to include the functions for drift mode to use it properly.
Dena
Phoenix AZ
I am not sure that is an issue. I think all the 2024s come with the ability to have a drift brake. I am not into wearing out tires in a hurry but I think you need to set up the correct app and then the hand brake functions as a drift brake. Look at page 407-408 in the manual.
Mrswear2god
Ontario
You need the pp to get the hand brake instead of the button
Dena
Phoenix AZ
I am not sure on that point because I haven't seen a GT and my non handling package Dark Horse has the handle. It appears you get it no matter what with the Dark Horse.
It does pose the question as to if the app is present in the GT without the PP. If it's not, things get a little more complicated.
in theory you can retrofit the drift brake, but in reality it would require replacing the center console, getting all the parts for the handle, and replacing the center console+dashboard wiring harness, due to a different pin layout between drift brake and regular parking brake. labor times for the wiring harness alone are likely in the 18 to 20 hour range
packfan021488
New Jersey
2024 Shadow Black GT PP
I'm also almost positive you have to get the PP to get the drift brake. I love my S650 but the one thing I absolutly hate is the fake hand break. I just can't get used to the brake not have the master cylinder feel. I know it actually works but not hearing that clicking sound when I pull it up makes me cringe almost every time
Someone should gen up an accessory with a weighted spring that you would set in place to flip [the] switch but then the software question comes up …
FazeJena
Glen Allen
2024 Ford Mustang Gt Premium
I bought a GT with no PP but Brembos so I have two brakes on my rear tires. I want to assume there is something you could do to get a drift brake but I'm not sure how to
BrianJ77
I would rather have a cable operated e-brake as well, but I love the fact that I can grab and pull a handle over the button. Haven't used the drift brake feature yet. Still breaking her in with just 290 miles on the odometer.
Mustangman2016
New york
2024 mustang gt
Does anyone have an update on this topic I have purchased the drift brake but I’m struggling with the wiring. Sorry for reviving this thread
i think you are on your own, man. nobody else has really tried this due to the complications with it. i hope you know how to do wiring
Is the drift function software controlled? It sounds like you bought a handle to replace the switch but somehow they use different wiring for the connection (unable to color match wires)?
The inputs from the original park brake PB are discreet (on or off), the drift handle uses an anolog signal (continuously variable based on how much it is pulled up). the correct wiring is likely not there and programming is different... likely not something that can be changed enough with forescan... module programming for a different car (VIN) probably needed. I would not try this myself... and I have all the wiring diagrams, programming software/interface and extensive wiring knowledge... seems like more trouble than it is worth, especially if you don't have all of the things I just listed.
