Disabling Electronic Sound Enhancement and ANC for subwoofer install
marcus50
2026 Mustang Dark Horse
ESE is clearly spelled out in the order guide for the Ecoboost and the GT, but not for the DH... though every DH asbuilt file I have looked at has ESE enabled!
My Dark Horse has this configuration:
Code:
ACM 727-01-01
original: BC33 14F4 1037
new:      xxxx xxxx 0xxx
The difference in interior noise is very noticeable, IMHO it's absurd how much fake noise was generated through the speakers.
Code:
ANC 727-01-01
new:  w    xxxx xxxx 0xxx
So noticeable it can be recorded?
if you change the vehicle type to a mach-e is it more pronounced?
marcus50
You can tell the difference just by starting in normal exhaust mode, that startup roar is mostly fake (now that it is disabled). While driving it is similar but overall the noise level is reduced, acceleration sounds less bassy.
Not sure if a recording would work since most microphones in phones etc. don't record low frequencies that well.
Starship Enterprise
MD
2025 Mustang GT Premium
Interior conversations have a weird muffled sound. Especially with the stereo on, even on low. Like a dullness you get from noise cancelling headphones.
I'd get Forscan maybe someday ...just to strip any false sounds out of the interior.
Is it possible to pull some fuses for the audio system amps to test the artificial sounds?
Just asking.
Starship Enterprise
MD
There's 2 amplifier fuses and one "Audio Unit" fuse. Not sure what pulling those may do. Some have talked about removing the interior mics which feed noise cancelling info, but there's like 3 or 4 of those I think.
Is this stock or have you modified something?
