Correct tire width for s650 lowered
Rush hour 89
2024 GT
I was looking at a set of hre rims
20x10 front 35mm offset
20x11 rear 50mm rear offset
Front tires would be 275/30ZR20
Rear tires would be 305/30ZR20
I was going to lower the car on Steeda magnaride sport springs thanks
agreywolfe
Oklahoma
Shouldn't be an issue, that's about .5" shorter than the stock pp 275/40s. For reference here's my HRE setup on 285/35 and 315/35. About 1.5" taller than your proposed setup
S650 Mustang Correct tire width for s650 lowered 20240420_191218
Edit to add: stock magneride suspension
Magic88
Bennington
Here is mine with steeda magneride lowering springs.
275/35R20 20x10 35mm offset
305/35R20 20x11 50mm offset
S650 Mustang Correct tire width for s650 lowered 20240404_170603
Rush hour 89
2024 GT
Those look nice the finish looks good against the color. How’s the ride quality
agreywolfe
Oklahoma
Pretty decent, I went with this setup specifically because it was the same size tire wall as my 275s.
Project6GR Wheels
Los Angeles, CA
Shelby GT350R
heart eye emoji!!!! this looks great !
tj@steeda
2015 Steeda Mustang
Magic88
Bennington
How’s the alignment? Camber ?
I didn't keep the alignment printout because it was pretty close to being within the green on both sides for camber. I believe it was green on the driver's side and passenger side was 1/10th of a degree outside of green, so in the yellow. I've tested it numerous times driving it and it drive's perfectly straight. Good enough for me 😁
Dave2013M3
El Segundo,Ca
Perfect, although I would do a 285/30/20 up front.
Carter1776
Indiana
2024 Mustang GT Atlas Blue
Velgen VF10s
Steeda Lowering Springs
Front camber; FL -1.8 degrees and FR -1.5 degrees, both in green.
35mm offset F
52mm offset R
Nitto NT555 G2 F&R
275/35R20 F
305/30R20 R
Very very slight rub on a inner wheel well liner plastic clip on hard front decompressions or bumps on both sides but thats solving itself by rubbing the clip off lol.
S650 Mustang Correct tire width for s650 lowered sully
