Convertible covers for side when top is down.....
OldCoastie
Kissimmee,Fl
I just learned that two covers are suppose to be provided upon delivery that can be manually instoll to cover that large long void when the top is down. Does anybody know about this, and can you verify for me they are suppose to be provided..... Thanks
DT-GT
Many years ago in early S550 days the covers were provided, but Ford stopped because of quite a few issues. If driven with them in-place they would rub and sometimes fray areas of the top. And, they had to be removed and stored before raising the top. So, they were discontinued. But, if interested in purchasing you can still find them in a few places.
I got them for my 2022 S550 convertible. Modified them with some additional foam and felt in certain spots so that they would not damage the top’s material. They also fit my S650. I’ve used them when my car is on display in a show, but generally do not mess with them at any other time. I have them so they’re available for car shows. If I did not have them, knowing what I do now, I wouldn’t spend the time or effort.
They can easily damage your top - and - quickly. Stay away from them IMO.
jbrnigan
S. Indiana
I bought a pair of these covers on the marketplace for 20 bucks - they were NOS - brand new. I have had them on and off for 1000's of miles and not the first sign of wear, abrasion, discolorization or other "damage" to the fabric of my top. The foam "gaskets on my covers are/were pristine and contact the the folded top fabric where they are supposed to. I get it, some previous owners had "issues" that I haven't experienced. I like the way they cover the "gap" when the top is folded. Before uising, I found leaves, bugs, and other debris in that opening housing the folding mechanism.
S650 Mustang Convertible covers for side when top is down..... 20260612_192906
S650 Mustang Convertible covers for side when top is down..... 20260612_192830
Alex381
I’ve got about 10k miles on my GT convertible and primarily with the top down. I wanted the covers when I bought my car, but it didn’t include them. I figured I’d go a couple thousand miles and see if I still cared. I don’t at all. They’re completely unnecessary, they can damage the top, and they only make it take longer to drop or raise the top. I wouldn’t worry about it.
OldCoastie
OldCoastie
Kissimmee,Fl
Thank you so much for clearing thi up, nice to know the story.....MANY THANKS
Rolinuss
Switzerland
S650 vert
Over here in Europe Ford still provides them as standard equipment for all S650 ragtops and I don't think it's any different for their main market... maybe you should get in tocuh with your dealer.
OldCoastie
OldCoastie
Kissimmee,Fl
Got to the bottom of the Convertible Top Side Panels, simply put Ford stopped providing them on all S-650 generation. Through some of my contacts this is what I got from a very senior Ford executive....
About those infamous Mustang Convertible Top Side Panels. The panels are not missing, the panels were never issued with any of the S-650 generation Mustang Convertibles.
Several years ago in 2014-2018 the early S550 days the covers were provided, and placed in the trunk. It was the responsibility of the dealer to make the new owner aware of these and instruct how to install, remove, and store these top side panels. It proved to be more trouble for both the customer and the dealers. Neither wanted to deal with having to manually installing and removing and for the owner the panels damaged the convertible top.
Between 2016-2017 very major issues came to light with using them while driving. Over 300 cases were reported when driving with panels installed in-place, the panels would rub against the cloth top causing serious fraying, discoloration, abrasions, and even tearing of the top, after about 1,000 miles.
As a result Ford redesigned these panels adding foam padding and were reissued during the 2018 model year. Did not work, foam fell off or wore down resulting in caused damage. In turn, Ford was responsible to fix or replace more damaged tops under factory warranty.
Ford stopped providing side panels in 2019 production year. Shortly after reissue the same problem was brought to our attention, many people just did not use them because they had to be manually removed and stored before raising the top. It was determined by production engineering the distribution of the Top Side Panels would be discontinued, and surplus would be offered for sale for those who would like them.
The Top Side Panels were discontinued and never came back into production. No panels are provided for any of the S-650 generation. Still a few hundred exist which can be found with aftermarket vendors but not Ford, Found under Part# 763-1045CC0K. You can still find them much cheaper on aftermarket dealers and even on Ebay. Also if purchased Ford highly recommends not drive with these top side panels in place because of the issues of fraying the top due to excessive rubbing the material of the top. Ford is not responsible for any damage as this is not a production issued part. Use only when static display of the car. Hope this helps you out, had to look it up."
This what a found out.....
Rolinuss
Switzerland
S650 vert
anyway, my car (MY 26) came with the panels and the attached picture shows a top down view of a Euro S650 for a magazine road test. Why should Ford do such a thing???
Second photo shows the trunk of my car with the panels thrown in.
Maybe they had a surplus of panels and just threw them in the trunk of all cars destined for Europe or Down under, who knows...
S650 Mustang Convertible covers for side when top is down..... ford_mustang_convertible__yellow_2024_005
S650 Mustang Convertible covers for side when top is down..... be26d181-bffc-5320-8596-dc409b050000
OldCoastie
OldCoastie
Kissimmee,Fl
My post pertains to cars sold in the US and Canada,. Europe falls under a different division at Ford. The color Yellow is not offered in the US on the Mustang.
Neggytive
Ford stopped shipping them with the cars during the 6th gen series, the inserts rubbed against the top leaving wear marks.
The 6th gen ones fit the 7G cars, some of the 6G guys with 7G cars found theirs in the garage and used them, I ordered a set from Benny @LevittownFordParts almost 2 years ago right after I got the car.
Do you know how many times I have put them on the car?
ONCE !!!!
At some point in the future I'll do cruise nights with the car and I'll pop them in on arrival to make it look better
The cover on my S197 was much nicer, and Ford offered something besides black as a roof color
S650 Mustang Convertible covers for side when top is down..... IMG_20240923_144350519_HDR
S650 Mustang Convertible covers for side when top is down..... IMG_20240923_144315731
S650 Mustang Convertible covers for side when top is down..... IMG_0128
glenng6
Easton, PA
Mine are the OEM covers, originally made for S550. I've been using them for more than 18 months and haven't had any wear or damage. I actually used them tonight when I drove to a meet-up about an hour from my house. I don't use them unless the trip is longer than a half hour because it takes a bit to install them. Here are some images with part numbers. Also, if you have them installed correctly, you can't put the top up. If they are not installed correctly, you can put the top up and they will end up on the ground. I plead the fifth because I might incriminate myself. And here is the website where my dealer bought the covers:
<https://lmr.com/item/LRS-7631045CC-K/ford-mustang-interior-rear-quarter-panel-covers-15-24-vert>
S650 Mustang Convertible covers for side when top is down..... Image 2
S650 Mustang Convertible covers for side when top is down..... Image 3
S650 Mustang Convertible covers for side when top is down..... Image 1
Clawfford
Dayton, OH
2014 GT Convertible (Ol' Red"), 2025 GT Convertible ("Daisy")
I love mine, although I did see people saying they had damaged their top, So before I ever used them, I went to the hardware store and picked up some sticky-backed foam insulation strips and made sure the underside was nice and padded. Never had any indication of damage to my roof material.
MY PROBLEM: I always forget them. Time after time, I put the top up and hear them go “plop!” on the ground. I keep wanting to make myself a reminder note up by the lowering button, but I never got around to it.
In the middle of the Summer, they’re always on. As the weather starts to get “iffy”, I set them aside. They’re a MUST for Cars ‘n’ Coffee! Nice, clean look.
S650 Mustang Convertible covers for side when top is down..... IMG_5323
Snakebyte
West Central FL
Mustang, Fusion
I keep my covers in the original plastic bags still. They are tucked close to the back seat as well. Storing in those bags works well preventing scratching, except that it doesn't look so neat in the trunk appearance wise.
Snakebyte
West Central FL
Mustang, Fusion
Great points. I replaced the foam which woefully deteriorated in a short period. I replaced it with dense outdoor weatherstripping.
Note: When doing so, ensure you use thick enough foam to ensure no plastic-to-fabric contact. But.....don't apply too thick of foam. If you do, the cover will bow, preventing the proximity sensor from working. (The sensor prevents raising the top while the covers are in place.)​
Another thing I did was use my Dremel rotary tool to notch the plastic where it can contact the front of the folded convertible fabric. It confounds me as to why Ford didn't give an extra 1/8-3/16 inch clearance there to prevent hard chafing there.
