Connecting CTEK/Battery Tender
hoopstir1
Limerick Pa
tocoma ,harley davidson, mercedes benz,2025 GT Ford Mustang
So its okay to hook the tender to the fuse box or the battery ? which is the best
5.0ALM
Brisbane, Australia
Starship Enterprise
MD
2025 Mustang GT Premium
ah…I just go to newest posts and didn’t notice the forum section. Whoops…
But the basic is the same right? Fuse box and ground post?
insaneBoredom
Cleveland
2025 Ford Mustang GT Convertible PP
Correct. See my post earlier, positive on the fuse box and negative onto the post on the strut tower. There is a red tint because of the terminal protector.
DFB5.0
Australia
Mustang GT Fastback
Incorrect.
RHD cars have the battery on what is USA drivers' side. So while the fuse box is on the same side for RHD and LHD, the negative ground post is on the other side.
S650 Mustang Connecting CTEK/Battery Tender IMG_2810
S650 Mustang Connecting CTEK/Battery Tender IMG-2235
OzzieRoss
Perth - Western Australia
2024.50 Dark Horse
I suggest reading the entire thread and you will find some discussion on this
Has anyone had this warning with a battery tender hooked up to the battery itself?
bfets
bfets
Western Australia
insaneBoredom
Cleveland
Incorrect.
the “correct” is referring to connecting to the fuse box and ground post, not direct to the battery. Does it really matter what side of the car one refers to?
DFB5.0
Australia
Mustang GT Fastback
You reference the fitting of the positive cable to the fuse box and the negative to the ground post.
On right hand drive vehicles, the main negative ground post is on the opposite side of the engine bay, and therefore the opposite side to the fuse box. There is a negative ground post for the fuse box, but it's obscured by the strut tower brace, and if you have the Ford Performance Oil Catch Can, that post is used to mount a bracket and therefore unusable for this role.
Deano1978
NSW
Is there a spot on the same side as the battery that I can safely use for negative?
Going away for 1 month and using a borrowed tender that doesn't have the reach required to connect to the negative stud near the fuse box.
bfets
bfets
Western Australia
Going away for 1 month and using a borrowed tender that doesn't have the reach required to connect to the stud bear the fuse box.
I just used the negative charging stud, but I'm sure there will be something closer to the battery as well.
S650 Mustang Connecting CTEK/Battery Tender 1757377997455-56
