Carbon Filter RWHP?
Stanzi
Whitesboro, Texas
2024 Subaru WRX tR
Tony compared a 2021 Mach 1 without carbon traps to a 2022 with them, claiming "this is the only difference between the two cars". BS. And that proves NOTHING, other than one car returned different numbers than a different car. Run the 22 with and without the CTs.
I've seen plenty of other videos with dyno runs that confirm there is no appreciable HP difference with the S650 by removing the carbon traps. And everybody knows that changing a factory CAI for an aftermarket CAI *with no other change* will produce little to NO difference in HP.
Presenting something AS fact doesn't make it fact.
what’s hilarious about this statement that there’s nothing different between the cars is that exact same cars can put down different dyno numbers. So, as you said, unless you dyno before and after on the same damn car, the numbers are useless!
And THIS is all that matters.
if you can’t gain MPH in the trap, you didn’t do anything worth modding.
Consistency
For really small changes, even using the same car is no guarantee that the difference is real. Lots of things can cause a horsepower change from one pull to the next, oil temperature, the computer pulling timing, no two pulls are ever really exactly the same.
