Air diffuser
BrianJ77
You can do it. Need to Jack up front having the wheel turned as needed to maximize room. I had to remove them to partially loosen inner fender to cover square hole with kydex cover. Use jack stand.
I was able to install the strakes on my GT PP without raising the front end. Take out the bolts and reinstall them with the strakes. Three bolts if I recall correctly. Takes 5 minutes.
Ice Man
2024 Mustang GT PP
Purchased my GT PP in February. Came across this thread and looked under. No strakes. Called the dealership and they had no idea what I was talking about. Sent them the PDI. Got a quick call back with an apology. They ordered them last night and will get installed next week.
Spaghettir101
2005 Mustang GT
Love to see it
Ice Man
2024 Mustang GT PP
Got them installed today. Took them about 15 minutes. 2 hour drive round trip lol!!
ListedGuru
Mercury
Just to confirm these are not found on a regular GT without PP correct? Just want to make sure I'm not missing anything either.
24BlueStang
Oklahoma
2024 Mustang EcoBoost
What are these for? Idk anything about them so just curious
Darkness24
US
Dealer did not install my strakes per the PDI either!
There is a video out there somewhere showing all the extensive wind tunnel testing. I'm sure Ford thought these were helpful to be on PP cars. Car manufactures would be glad to save a nickel anytime they could. I'm sure these can't be that expensive and if I had GT without them I would install them. Again It shows that the open hole by the rear front tire may have something to do with turbulence.
ListedGuru
Mercury
Well I just picked up my GT so I'm curious about these. So your thinking the opening behind the front wheel wells are intentional?
So far no one really knows. There are plenty of speculations. My thoughts probably will be flamed. If one does any research on wheel well turbulence you will find that is a real thing. I speculate Ford designed the inner wheel wells for the DH and somehow just carried over to other models. This would also keep from having two different part numbers.
I still closed up my openings regardless
of what its purpose.
Ice Man
2024 Mustang GT PP
Correct. According to the form these come stock with a Darkhorse or a GT PP. Mine is a GT PP.
