Air Design Rear Decklid Appliqué -not a fan
Tamadrummer88
Finicky
Austin, TX.
2024 Mustang GT Premium, 2023 Honda Civic LX
When I bought my Mustang, I ordered the Air Design Rear Decklid Appliqué for the S650. I don’t know why Ford decided to get rid of the gloss black appliqué for the S650. It really finishes out the Decklid. And my car being white, it really looks plain back there
S650 Mustang Air Design Rear Decklid Appliqué -not a fan IMG_3908
Don’t mind the tape, I had my detailer remove the GT emblem for me in anticipation of getting the Decklid appliqué.
when I took it out of the box, this is what I got:
S650 Mustang Air Design Rear Decklid Appliqué -not a fan IMG_3903
S650 Mustang Air Design Rear Decklid Appliqué -not a fan IMG_3907
Right away, saw a problem. According to the instructions, you need to drill out the two indentations on the back if you wanna retain your badge. I personally think Air Design should have two versions, one with the holes neatly drilled, and one without.
second, when I dry fitted the appliqué on the Decklid, it didn’t appear to line up with the backup camera nicely. At first, it was obscuring a 1/4 of the camera. I don’t know how much of the view it would block, but that didn’t sit right with me. There is a lip at the bottom that has to sit with the bottom lip of the Decklid in order for the double sided tape to stick. I could try to move the upper part over the camera to make it sit better, but it just didn’t look right to me. It almost seems like the holes weren’t milled to the right size.
S650 Mustang Air Design Rear Decklid Appliqué -not a fan IMG_3910
S650 Mustang Air Design Rear Decklid Appliqué -not a fan IMG_3911
Coupled with the lack of a drainage channel for water, I don’t think this is a good idea. I’m gonna sit on it for the week, and if I don’t wanna risk it I’ll return it to the dealer.
now I gotta go get another GT badge lol.
Paul's stable
Maple Ridge BC Canada
That last picture looks like an eye ball.
DT-GT
I also wish the black area was standard. I think it really makes the rear of the car look better. I ordered the appliqué from Ford and received the same appliqué as you with the same red GT and pony double-sided tape. My car had the GT, which I removed with no problem. I drilled the holes in the appliqué per the instructions at the spots marked on the appliqué. They lined up perfectly with the holes in the car where the GT fit. The hole for the rear view camera lined up correctly on mine. The end result looks good and fit correctly. I used Ford Reward points for the purchase, so not too bad. Either some designer thought the solid color on the rear looked good, or it was another way for Ford to save a few bucks.
Hopefully you have the emblem that was originally on the car.
Tamadrummer88
Tamadrummer88
Finicky
Austin, TX.
i ended up ordering another GT emblem.
sdsteele2
Tennessee
24 Mustang GT
There should be a small black vinyl “donut” to go around the camera and hide the body color.
I took the panel off after about a year of having it installed. There was minimal dirt behind the panel. I did use 3M adhesion promoter to help the adhesive tape stick when I installed it.
Tamadrummer88
Tamadrummer88
Finicky
Austin, TX.
there is, but the hole for the camera is cut really weird and doesn’t align nicely with dry fitting.
DT-GT
Just curious. Did you remove and reinstall, or did you decide against it for some reason?
Yamazuki
North Dakota, USA
I ordered the Air Design one as well, but then found one on BlueOval that is supposed to be a genuine Ford part with the Dark Horse badge already attached.
Needless to say, the Air Design one is still new in the box.
The other fit well but the hole for the camera did seem a little off.
No issues with it obstructing the camera view however.
S650 Mustang Air Design Rear Decklid Appliqué -not a fan IMG_0852small
BlkJack
Miami
2024 GT Premium, PP, A10
So it does obscure the camera and what irks me is they know it BECAUSE THERE HAS BEEN NUMEROUS complaints about it and instead of fixing the design they just keep selling them flawed and don’t give a Rats ass. Which speaks volumes for who they are 🤷‍♂️😡
SSuperDave
Friendswood TX
I bought an aftermarket one for a lot less money that looks identical to the Ford one. It fits great and I reused my emblem with the tape that they included. I agree that it needs to be black back there specially on lighter colored cars.
Yeagerbomb81
Charleston, SC
2023 F150, 2023 Expedition, 2025 Mustang Gt on order
I have this and agreed with everything you said. I added some double sided tape to mine, drilled out those 2 spots and it turned out really good. It seems to fit better with the tape and pressure applied to it. I got my for “free” with ford pass points along with their front splitter which needed more tape and I drilled to holes to use Christmas tree fasteners at the back side of the bumper to make sure it stayed if it got bumped or tape let go. It’s over priced for what it is, and I’m surprised it’s a ford branded accessory. Takes a little too much work to make right but they turn out nice and look good
S650 Mustang Air Design Rear Decklid Appliqué -not a fan IMG_1908
S650 Mustang Air Design Rear Decklid Appliqué -not a fan IMG_1905
I did my car yesterday with a black protection film i didn't like to have a glass hanging back there with a tape only
This is a way better solution. Looks great.
