Abilor
Abilor
Albany, NY
Further adventures! Got the MGW Shifter I got for my birthday down off the shelf, boned up on the install procedure, and managed to get this on the car. The experience was not for the faint of heart, a lot more involved than any other Short Shifter I've installed, and there's some tips and tricks I'd share below.
Started by getting all the tools set up and ready along with parts the night before. This made a huge difference:
S650 Mustang Abilor & Maude - Build & Maintenance Journal 20250618_233527
Started early the next morning, around 9AM on a Saturday. Initial breakdown was easy except for this part, for which I invented the "Abilor Three Flathead Shims" maneuver to finally get stock parts off:
S650 Mustang Abilor & Maude - Build & Maintenance Journal 20250619_104942
Got the car up on the QuickJacks, and started poking around.
S650 Mustang Abilor & Maude - Build & Maintenance Journal 20250619_130736
S650 Mustang Abilor & Maude - Build & Maintenance Journal 20250619_133933
One thing I noticed right away is that at top height of the QuickJacks, I had plenty of clearance under the car, and given the sheer number of extensions and flexible heads I have for my electric ratchets and impact drivers, I made the bold choice to do the job WITHOUT removing either the driveshaft or exhaust, *mostly*. Here's where the trouble began, with this guy:
S650 Mustang Abilor & Maude - Build & Maintenance Journal 20250619_142726
That's the Top Arm bolt, probably the trickiest thing about this project. It's where I stalled for about 45 minutes to an hour just scratching my head. This bolt is massive when you finally pull it, and is one of two major mechanical connections to the transmission itself. The bolt is around three to four inches long, and the transmission tunnel isn't wide enough to fully unseat it. That's why all the directions say to drop the transmission by loosening the K-Member, which I was able to do and didn't even need my jack to support it. The problem there was I was about a quarter inch too high still, unable to remove the bolt. The fix, and this is dubious, is to very gently loosen the exhaust coupler screws, talking maybe a turn or two; the transmission will drop just a little bit more, and voila:
S650 Mustang Abilor & Maude - Build & Maintenance Journal 20250619_145952
Things got a bit easier from there. Aside from the top arm bolt, there's another 1/2 inch (13 mm) bolt that's hidden from you where the shifter linkage itself connects. Needs tenacity, and ability to settle a 13 mm ratcheting box wrench onto the nut; I was able to use one hand to steady it, and one to turn the nut, finally got it off. Disassembling the stock shifter for removal after that was cake:
S650 Mustang Abilor & Maude - Build & Maintenance Journal 20250619_155022
The FINAL little gremlin was getting the shifter linkage lined back up so you can use one of the stock screws to connect it. This gave me fits, as I couldn't get things to line up quite right:
S650 Mustang Abilor & Maude - Build & Maintenance Journal 20250619_175427
Fix for this, a little embarassed to admit it: Shift gears! I had to move it from first to neutral (I think), and the gates opened finally:
S650 Mustang Abilor & Maude - Build & Maintenance Journal 20250619_181435
From there, easy peesy, put it all back together, and behold its wonder:
S650 Mustang Abilor & Maude - Build & Maintenance Journal 20250619_203102
Shifter itself feels amazing. Super mechanical, and the locking points where you fuse it to the transmission really inspire confidence. Very crisp, very machined, and the vibration feedback is fantastic. Push down to reverse lockout is how the car should have come, in my opinion, no more fiddly ring. 2 to 3 in particular is vastly improved; the gear is right there, ready to be grabbed. 4 to 3 downshifts were a problem stock, I'd get locked out and grind the gears once in a while; this kit has completely eliminated all of those alignment problems.
One small issue is that the knob keeps coming loose after using the lock nut, but I chalk that up to not using loctite while I wait for my custom knob and lock nut from Billetworkz. Those I will glue up with loctite, and it's another job in the bag.
100% can recommend the MGW X-Spec, with full 25% reduction. Car feels so right now. Job took about 10 hours overall, taking my sweet time and losing about 2.5 to 3 hours just to gremlins.
Abilor
Abilor
Albany, NY
I'm impressed you have the QuickJacks hanging on the wall. They weigh about 100+ lbs each.
I'm very careful to mount to the center of the stud using a 3 inch deck screw; that wall is also coupled to an I-Beam in the garage. I've had 'em on and off several times now with no issues. Cannot overemphasize how much I love the QuickJacks. Only problem is now people are aware I basically have a home auto shop; changing Mother-in-Law's oil tomorrow lol...
Abilor
Abilor
Albany, NY
Good news on car audio front, all equipment operational and fully mounted, now ready to move to the Beauty Panel stage after ironing out this gremlin. More soon; motor mounts and sway bars have given me the itch, and may be going on soon. Apex wheels, Kooks CBE, and the Auto Addict tail lights are all still getting cast/forged/built...
37.5726028 / -85.1551411
Concur, really like mine too. Used them constantly for previous race car, but now that that has been sold, QJ's are sitting in garage collecting dust as I have no desire of doing any home maintenance on the S650.
Abilor
Abilor
Albany, NY
Can I ask why not?
Abilor
Abilor
Albany, NY
Fourth of July came and went! Our family went up to Lake George to enjoy the holiday, but I managed to sneak in the install of my Diode Dynamics map light module, and I have to say, I'm very impressed. DD's kit arrived promptly in good shape, and contained the module itself in a static bag, along with stickers (my wife and I love stickers), and for MAJOR cool points, two panel popper tools which I used in the install. A QR code points to documentation, so you're always getting latest, and the unit itself installs super easy. Fiddliest bit was the spring-loaded toggle, but even that was a cinch. Total time was literally less than ten minutes, and the results are pretty great. Maude is Molten Magenta, so, of course:
S650 Mustang Abilor & Maude - Build & Maintenance Journal 20250707_151658
S650 Mustang Abilor & Maude - Build & Maintenance Journal 20250707_151709
S650 Mustang Abilor & Maude - Build & Maintenance Journal 20250707_151720
S650 Mustang Abilor & Maude - Build & Maintenance Journal 20250707_151726
Very pleased with the whole install overall. Wife is thrilled to be able to turn on the "Mexican Taxi" look anytime she wants. Keeping the regular map lights as an option made me all too eager to pull the trigger.
Thanks, Diode Dynamics!
Abilor
Abilor
Albany, NY
Billetworkz came through and sent this custom knob for MGW X-spec. Significantly adds to the "Evil Wizard" low key theme we've been going for.
Thanks Billetworkz!
S650 Mustang Abilor & Maude - Build & Maintenance Journal 1000021863
S650 Mustang Abilor & Maude - Build & Maintenance Journal 1000021864
S650 Mustang Abilor & Maude - Build & Maintenance Journal 1000021865
Abilor
Abilor
Albany, NY
Sidenote, where / how did you attach the license plate?
With this here doohickey from Cravenspeed. It's their universal grill mount - i drilled holes in the plastic behind the grill to make room for bolts. Best part is it leaves the full, 100% radiator core open to the air with no blockers. Holds like a champ, especially with blue loctite.
Abilor
Abilor
Albany, NY
Jeebus, I'm behind on videos. I've still got the motor mounts one brewing, but in the meantime, have been consumed with HPTuners and finally getting under the hood to tune. My wife and some friends have convinced me to start a YouTube channel to keep logging adventures, so here's a second look at what I've discovered about *dual* MAF tuning so far... Further videos as more and more R&D plays out.
Paul's stable
Maple Ridge BC Canada
My Quick lifts hangs on the wall also have the pump unit mounted to the wall. Also welded roller balls to the underside of the lifts so they can be easily moved when trying to set up the lift.
