89Trooper's Garage - Modification Journal
Alan Applegate
Roswell, NM
Is there a reason Mustang drivers need to jack up their cars to the point they require jack rails under it? I just hope it isn't for the same reason my neighbor jacks up his CTS-V? ....to wash the insides of the wheel rims? Talk about OCD!
89Trooper
89Trooper
Central Florida
Here's one example: I never take my car to get new tires installed. I take the four wheels in my wife's Edge, have the new tires put on, and take them home. I don't trust tire places and would mount and balance them myself, if I could.
But, yes, once there all off, I do wash the inside of the rims. :giggle:
89Trooper
89Trooper
Central Florida
Sunvisor Solutions Sun Visor Label Covers
Date completed: 10/30/24
Purchased from: SunvisorSolutions.com
Another simple modification I do pretty quickly is to cover the ugly white/yellow warning labels on the sun visors.
S650 Mustang 89Trooper's Garage - Modification Journal IMG_7054
There are cheaper options (vinyl), but these are actually made out of headliner material. The color chart (which you do have to purchase) helps you pick the best color/material.
S650 Mustang 89Trooper's Garage - Modification Journal IMG_7046
I'll save you the $5.95, if interested. For our black sun visors, "2350 Ebony" is the perfect match, and you will need a pair of 4.5" x 5.5".
S650 Mustang 89Trooper's Garage - Modification Journal IMG_7047
S650 Mustang 89Trooper's Garage - Modification Journal IMG_7055
Is it legal? Yep... check their FAQ section.
Do they look way better than the eyesore stickers? Yep! :sunglasses:
S650 Mustang 89Trooper's Garage - Modification Journal IMG_7060
89Trooper
89Trooper
Central Florida
Performance Pack Carbonized Gray Rims
Date completed: 11/17/24
Purchased from eBay (this Seller)
This thread tells the whole story, but I did end up going for the Carbonized Gray rims... obviously, or I wouldn't be writing this.
Which rim do you like better? | Mustang7G - 2024+ S650 Mustang Forum (Dark Horse, GT, EcoBoost, GT500, GT350, Mach 1)
I did purchase four front rims/tires (9.0") so I could properly rotate tires. I've never been a fan of staggared tire set-ups. If not a daily driver, I wouldn't care.
I think it's a night and day difference!
S650 Mustang 89Trooper's Garage - Modification Journal IMG_6834
S650 Mustang 89Trooper's Garage - Modification Journal IMG_7213
BizJetTech
Stuart, FL
2024 GT base Vapor Blue
Purchased from SunvisorSolutions.com
Great idea and thanks for the info - I will order today👍
BizJetTech
Stuart, FL
I was going to go the same route, BUT, I dont like the OEM wheel offsets.
I like to push the wheel further out (just a little) and for that I will go aftermarket
89Trooper
89Trooper
Central Florida
Talking about offsets, the 9.5" rim has a 7.5mm greater offset than the 9.0" rim, so they stick out (almost) exactly the same (the difference is .025"). I'm going to look into wheel spacers, either 20mm or 25mm, to bring both the front and back out a little bit.
BizJetTech
Stuart, FL
That is an option but I'm not a fan of spacers, but those wheels look really good for sure, congrats
89Trooper
89Trooper
Central Florida
Same... but I gave them a try on my 2015. Something like the link below. Gotta be hubcentric, of course. A good 6 years or so on the car and no issues. I even hit a curb cutting a corner two tightly in a dark parking lot - it caught the right rear tire. Huge bang and cracked the rim. I had to order a new 50th anniversary rim (not cheap) and get it aligned. Not a single issue with the spacer, though.
Eibach Mustang 25mm Pro-Spacer Hubcentric Black Wheel Spacers S90-4-25-063-B (15-25 Mustang, Excluding GT350 & GT500) - Free Shipping (americanmuscle.com)
BizJetTech
Stuart, FL
Good to know, spacers look like good ones 👍thanks for the info
tj@steeda
2015 Steeda Mustang
The installation is correct. The jacking rail will be at a very slight angle. This does not affect the performance of the jacking rail.
You can reuse the factory front bolts, installed through the jacking rail flange, to secure them in place.
Best,
Tim
89Trooper
89Trooper
Central Florida
Best,
Tim
@tj@steeda thanks for the reply! Did they tell you what this plate is for?
Also - I was thinking: could the jacking rail slide in between the car's frame and this mysterious plate? I checked - it does line up with the holes this way. Then the plate would be at a slight angle, though, which may not be that big of a deal.
89Trooper
89Trooper
Central Florida
Escort iXc Radar Detector with Mirror Tap
Date completed: 11/22/24
The Escort iXc is nothing fancy, and sure isn't new, but man does it have some long-range detection! If it ain't broke, don't fix it (or spend $800 for a new one!).
Here's all you need to know about tapping into power behind the rear view mirror from @Interstellar :
HOW TO: Radar Detector Hard Wire Install with BlendMount | Mustang7G - 2024+ S650 Mustang Forum (Dark Horse, GT, EcoBoost, GT500, GT350, Mach 1)
Here's what I got from Amazon. There are cheaper ones, but this one is really nice quality:
Amazon.com: Radar Mount RJ11 Mirror Wire Power Cord for Escort Radar Detectors - Max 360C MaxCam Redline (3005201IX) : Radar Mount: Electronics
Pics of the install - pins inserted and taped up. Plus no dangling cords... nicely tucked up and out of the way.
S650 Mustang 89Trooper's Garage - Modification Journal IMG_7246
S650 Mustang 89Trooper's Garage - Modification Journal IMG_7248
S650 Mustang 89Trooper's Garage - Modification Journal IMG_7420
Interstellar
Dallas
C6 Z06
Glad you found it useful!! Looks nice
BizJetTech
Stuart, FL
You've got me thinking.....best bang for the buck may be used take off OEM wheels with spacers 🤔
