3.15 vs 3.55 limited slip?
Farmer Fran
2024 GT Premium Vert
the difference is not only the gear ratio when you order the 3.55 option, it is a completely different limited slip system, clutches vs Torsen
That is why it is a $1000+ option for the 3.55 on the order sheet
If you have a 3.15 LSD in your mustang, the parts, meaning a 3.55 whole center section ready to drop in ( M-4001-88355B ) from @LevittownFordParts is under $1200 plus fluids.
The gears and install kit to swap out your existing gears will run you just shy of $500 and someone who can press bearings on and get the shim packs right for the proper gear meshing.
Just check the driveshaft flange as there are differences between stick and 10 speed cars
Plus you need to recalibrate the speedo for the new gear ratio, and maybe the transmission shift points
Personally I have never found myself wanting for the 3.55 the 3.15's work lust fine for me
Again, I will be corrected but I am pretty sure my 355 is no Torsen, just normal 355 LSD
Deleted member 17846
Guest
IIRC
315 if you want to boost because the A10 does not like 6th gear slams
355 for a good NA build
I am 100% sure I will be corrected. But do you run 87 or 91/93
Never heard off that before.
I always ran 3.55 - 3.73 FI and atleast 3.73 -4.10 NA
There's no fixed rule
Steeda runs 3.31 in their 2018 supercharged car, used 3.15 when the car was NA, and then they have 4.09's in their 2024 NA car
Guest
I don't think anyone said there was a "fixed rule".
kinelisch
I’ve had both S650 one with 3.15 and my current one with 3.55. I can honestly noticed a big difference in acceleration. Highly recommend the 3.55 gears.
palian414
orlando
2024 mustang GT
I did a lot of research on this and went with the 3.55. Mainly because that is what I noticed the majority of people go with on the automatics who tried both in person at a dealership.
I have seen a lot of videos of people racing 3.15 against 3.55 and the difference is completely unnoticeable. In theory, the 3.15 is faster on the top end, 3.55 is quicker in the initial acceleration.
there is not much difference in acceleration between a 315 and a 355 with stock tires because the tires are spinning but if you have bigger tires with a lot of grip you will notice a big difference !
Just because you have 3.55s doesn't mean you're spinning the tires lol. I've driven a GT in both gears and difference is noticeable. 3.55s are much snapier off the line. There's a reason they come on PP and DH cars.
palian414
orlando
2024 mustang GT
I agree, my 2024 GT 10 speed came with 3.15 gears and it could easily break the tires loose .I really wasn't happy with the performance so i purchased a loaded 3..55 differential from Ford performance and had it installed they also programmed the computer so the car knows it has a 3.55 gear. with the stock 255's i really didn't notice that much difference off the line because the tires were spinning like crazy however the engine got rpm's much quicker and the transmission shifted quicker of course and the car was much quicker through gears. still not happy with performance off the line i replaced the stock 255's with Continental 275's 340 utog very grippy tires, wow what a difference i could use a lot more of the GT's 486 horse power.
Deleted member 63380
Guest
Build your car for it's projected usage. In other words don't build a full blown dragster with top racing accessories if you plan on just profiling on the Boulshitvard, and taking a nice put to work, the store, or a country drive to see the landscape. A10, 3.15, A/W quality sport/tour tires, maybe a Steeda stop the hop street kit (incase), or even a Centrifuge SC, also incase. The centrifuge won't kick in until slightly after 3k rpm, will weigh nearly 190 lbs less than the Whipple. When and if it breaks down you take it off and send it to be rebuild, while still being able to drive the car. On the other hand Whipple will make that A10 and 3.15 come to life from the stomp of the accelerator. If it breaks down it's part could enter your engine and cost over 20K for e new engine and Whipple.
