2024 Gt PP.. BMR Springs / FP track / Bilstein / Steeda ??
86pagt
2019 Ford Mustang GT
Currently have a 2019 PP1 with BMR min drop springs and FP Track struts and springs. I picked up a used 2024 PP with 6200mi and then had the FP whipple installed. I want to try something different with the suspension.
I have a complete set of BMR handling springs and a set of BMR rear springs SP082s. I have seen on here somewhere on M6G maybe combine the handling front spring 246lb with the rear performance spring 740lb instead of the rear handling spring at 980lb. Now my thought is with the heavier weight of the whipple the handling spring will be fine. Should I use the performance rear or handling rear spring. Will it see the track.. maybe but not soon.. just a street car that I want to be able to handle curves, on/off ramps and so on. I will also install a front Steeda sway bar and BMR CB010 and CB762 that really worked well the ā€˜19. BMR camber arms and lock out, toe links and toe link bearing. Maybe later a rear sway bar for now leaving the PP bar.
Shock / Struts —- FP track, Steeda ProAction, Bilstein….Koni?? Undecided here any help would be greatly appreciated.. Thinking maybe Bilstein but much more $$ than the FP track or Steeda ProAction. Don’t know if I really want to mess with Steeda or Koni adjustable.
going to use the alignment I had in the 2019 unless others have something different
2.0 Front Camber
1.7 Rear Camber
.10 rear toe .20 total
.02 front toe
Any help is greatly appreciated
tj@steeda
2015 Steeda Mustang
Hello,
Happy to put you in contact with our tech team - they can help guide the conversation & provide some technical feedback - happy to help, you can reach me at [email protected]
Best,
TJ
svtfever
ALEX
CLARKSVILLE, TN
2019 GTPP1
Steeda is great. I had them at one point. Now I have the BMR handling springs with the FP Track shocks/ struts and WOW!!! It’s a firmer ride but not uncomfortable but the magic happens at speed and cornering. It’s like a match made in Heaven! They literally smooth out the faster you go but no loss in handling. It’s like it all gets more controlled the faster you go. HIGHLY RECOMMEND!
86pagt
86pagt
do you have any before and after measurements on the S650? What do you think the drop was with the SP083s. .50 - .75 ?
tj@steeda
2015 Steeda Mustang
