2024 Ecoboost 2.3 Turbo intake flange stud bolts torque spec? - 2024 K&N Cold Air Intake is Junk!
Tim_CO
Broomfield, CO
2024 Mustang EcoBoost Premium
Hello All,
Can anybody tell me the Ford torque spec for the bolts that's connect the OEM air intake flange to the turbo studs?
My son and I installed the 2024 version of the K&N cold air intake on my car yesterday. The instructions from K&N didn't include a torque spec.
For the record, after a half an hour driving and several hard pulls my son and i both concluded the K&N intake was slowing down the car. I pulled all that garbage out and it's going back to K&N.
Long story short, the OEM air intake feeds air from in front of the engine via a duct that firmly clips into the main airbox tube. This ensures the aurbox gets air from in front of the radiator. The K&N intake box doesn't have any means of securely connecting to said "cold air intake" tube.
After driving for half an hour, the K&N box had completely seperated from the intended cold air source by over an inch and was pulling in hot air from beside the radiator. It's a bad design.
I'll do a write up if anybody is interested. In the interim, I would really appreciate that torque spec. I googled for half an hour and I couldn't find anything for the 2024.
its 97in-lb or 8ft-lb
@Tim_CO ...... yes, the intake design was carefully thought out by Ford. I have noticed (obviously) sitting in traffic can warm-up the intake air but as soon as I hit 30 mph the twin air induction "snorkels" do their work and shoot cooler air right into the engine, then engine head temps and oil temps started to drop. I do not like any of the aftermarket air induction systems I have seen. I would rather monitor my oem Ford air filters and change them when they show signs of dirt. These 2024 Coyote 12:1 engines are very, very sophisticated. Ford has really perfected them, their induction and exhaust systems for very good performance.
Charleston SC
2024 Mustang 2.3
I also have a 2.3L and purchased and installed a K&N cold air intake and noticed the exact same thing. Where the main box comes out of the radiator area it doesn’t connect properly to the K&N tube. Tried a million times to clip it in better but it just won’t totally connect. Not to mention I have had a check engine light on ever since that won’t go away no matter how much I tighten everything down. No clue what the issue is.
dbroush7
2024 Ford Mustang EcoBoost Premium Performance
Hello All,
This is why, after a very careful study of the design and materials the k&n was made of, I avoided that option and instead got the induction tube from Eurocompulsion. It's been an excellent setup with objectively improved results. Unlike the k&n design which is over ambitious and under executed, it's made out of a great insulating material and builds on the already good OEM design.
Slothman
2024 Ecoboost Vapor Blue Nite Pony
The CEL is probably P04DB.
