Ninjak
Posting from the Shadows
- Joined
- Aug 19, 2013
- Threads
- 2
- Messages
- 1,391
- Reaction score
- 323
- Location
- The Shadows
- Vehicle(s)
- 2024 Dark Horse 2024 Bronco Raptor 68 GTA
Many cars up here have amber turn signals so for me it's not too big a deal.I had been contemplating those exact taillights. I really like the looks of them, just not so sure I want amber turn signals. If you could choose between red and amber like the Form Lighting ones I'd be all in!
Let us know how you like them once you get them installed.
BOTH shifters you PUSH DOWN. I have the MGW GT350/DARK HORSE shift kit so there is no pull up anymore, it's push down and over.@MCS: With the first shifter you have with the DH logo, how does it go into reverse? The second is OK, but I like the first one.
Your GT doesn't have the Fender Flares of a Dark Horse. I'm talking about this area. Ford replaced these on both sides this week when the supercharger was installed and now this one seems to be missing. Not sure if it's popping out or if my 285/35R20 are rubbing under braking or acceleration or maybe just bumps?
Wow your car is looking great. Where are you measuring your height from? My DH HP sit's at 4 inch's at the center of the front splitter.Ordered myself a set of Steeda Mustang Minimum Drop MagneRide Lowering Springs - Linear (2015-2026) to swap out my current Steeda Sport Progressives.
Hopefully that 200 lb/in front spring set helps with the Supercharger sag cause the 4" ground cleareance is killing me driving around Toronto.
Once this phase is done I can look at going back to 20" wheels and increase the ground clearance another 0.5"
How hard was it to install the new shifter?BOTH shifters you PUSH DOWN. I have the MGW GT350/DARK HORSE shift kit so there is no pull up anymore, it's push down and over.
They don't make that DH BRANDED full teardrop anymore. Not sure if Ford got mad at them or Ford maybe started charging too much but they don't make anything with a DH logo on it anymore. That is sort of a collectors item now I guess. It's just VERY big to grip so I thought I would change it out and try the short tear drop for a bit.
Thanks! Now that I am running a detailing product company it's pretty easy to keep the car looking shiny and new LOL I carry all the products I use on my own car with the exception of one (Brake Buster). As for where I measured; I think that may have been from an edge. Here is from EXACTLY centre.Wow your car is looking great. Where are you measuring your height from? My DH HP sit's at 4 inch's at the center of the front splitter.
I had Steeda.ca install it for me LOL I don't have anywhere I can drop down the transmission and do all that in my driveway.How hard was it to install the new shifter?
Your fender flares may have been installed wrong at the dealership. When I got mine they had not sold any Dark Horses from that Dealership yet so when they did mine they did them wrong. You are supposed to tuck one of the tabs between the carpet and the metal and then put the pin through it. That is a "load bearing" tab that helps with wind resistance etc.
I might have had this same thing happen on the passenger side with305/30R19 PS4S tires. I guess I need to get under there and look. It is loose up there in the same area. I did not realize there was a push pin of some sort there.
The Michelins are larger than the Trofeo RS in the same 305/30R19 size.
Found it! It was @smurfslayer -Your fender flares may have been installed wrong at the dealership. When I got mine they had not sold any Dark Horses from that Dealership yet so when they did mine they did them wrong. You are supposed to tuck one of the tabs between the carpet and the metal and then put the pin through it. That is a "load bearing" tab that helps with wind resistance etc.
If you look search FENDER FLARES on this site there should be instructions that one member posted (thank god).
