0mi to empty, but tank with gas
Rushstang
Phoenix
So today I turned the car on at work and this message was there, still have gas on it, is this a issue or it normally happen?
Not an issue. Im sure you “think” there is gas. Nope. You burned it all up in the way to work.
Here is what Im getting!
S650 Mustang 0mi to empty, but tank with gas IMG_5311
Dena
Phoenix AZ
Probably like the old style gauges. When the needle pointed to empty, you still had a couple of gallons in the tank. It was always fun figuring out how much was left because after several cycle you would creep up on empty then do a full fill. Knowing the size of the tank, you would know how much was left.
believe the meter over the DTE, something must have completely ravaged your fuel economy and you somehow got less than 0.1MPG. the estimate will return to normal eventually
you are getting better fuel economy than when i had my EcoBoost Mustang or Subaru Legacy
I have averaged 29mpg (imperial) over the last 7k miles on my S550 as a daily driver - that gives a range when full of over 400 miles. Regularly do 400 miles on a tank with a bit in reserve on an 80mph motorway run.
marcekb
-1 degree?
