“Drive mode not available” how to fix?
9itmare
Edmonton
2024 Mustang Dark Horse
This is driving me crazy every like 10-15 mins this shows up and car goes to normal mode
May be time to take it to the dealer... You could try unhooking the battery for 15 minutes and reconnecting it. There may be an issue with something causing it to return to default. Can you check for OBD codes.
DarkkMatter
Virginia, USA
I was having issues changing Active Valve Exhaust modes.
It tells me its not available when I want to switch it.
So, I go to custom profile, set it there, which is the one I'm driving on.
Then I go to the Settings where it shows the exhausts lined up and I see that Track was not highlighted, which is whats set for the current profile. I select that and "then" it switches and I don't get the "this isn't available" message. It works then.
Unless I'm doing something wrong. I have 1'st Custom Profile one set, but its not at those settings as stated on the screen.
I'm wondering if this isn't some safety feature where you can't select drive modes on the fly, when I was explicity told that I could by the Salesman.
DarkkMatter
Virginia, USA
Wouldn't be surprised. I still drove down the Interstate with it on Track mode. Was definitely loud.
Kevi
Baltimore
2025 GT premium night pony
First button I hit when I get in is my pony > race exhaust. Getting old. I might just do the h-pipe and some cheap loud mufflers or straight pipes. Screw the "active exhaust" that's just 2 more buttons I have to hit!
So i did remove the battery while installing steering wheel but the problem still persists
Installed a steering wheel?... I would check there to start!
