How to cycle between custom drive modes
Timry2
Fresno, Ca
2024 Mustang GT, Dark gray matter, 2020 F150 XLT Sport, magnetic
Good morning, wondering if someone can point me in the right direction. I have the premium with the pp. i figured out how to create custom drive mode, i just cant figure out how to cycle between the custom drive modes. I’m sure it’s easy, i read through the manual but it only shows how to cycle between all the drive modes. It will show profile 1, but I can’t get to profile 2, if that makes sense. Thanks for your help.
If I understand correctly, you only have one customer drive mode available for selection at any given time - that is to say, selectable on the steering wheel. You change which custom mode that is on the center stack.
Timry2
Timry2
Fresno, Ca
Im not real tech savvy and was completely lost. Got it now, thanks for the help.
bbsimpleson
San Francisco
I have an issue where the custom profile I created won't load. Whenever I select the profile, the settings briefly update to reflect the profile but then go back to normal. anyone else run into that issue?
I also miss my flip phone
Lakersfreak
Los Angeles
24 Mustang GT
I don't know why the drive mode always goes back to Normal after you turn the car off. It would be great to tie your mode to your key so that every time you start the car it automatically changes to your profile mode. Hope they can fix this in an update. All my older cars have this function already.
Almost certainly EPA certification. Raptor is the same way and it’s a PITA because drive modes aren’t just 2wd. On mine sport is 2hi and no vote, I have manually engage 4 auto. Every time.
I think the ’23-current will prompt you to ‘resume’ your last drive mode.
At least on the Mustang, its’ select the mode and GO. I wish the center stack gauge display would remain the same, it’s irritating to have select out of “trip meter” every time.
#FirstWorldProblems
Paul2020
Australia
2024 Mustang GT Atlas Blue
I have similar issue, my custom settings load except for speedo /tacho.
Screen shows Custom mode 1, sport steering, sport exhaust & normal dash instead of sport.
I reset the custom modes & started again but still have issue.
Anyone else had this & how fix?
