KPM Fuel Systems
Adelaide
S650
What are the benefits and advantages of upgrading to KPM Fuel Systems.
https://kpmfuelsystems.com/
  • World-leading 1500-2700 hp capacity: Direct replacement for OEM module.
  • Efficient and reliable: Maintains performance in both racing and daily driving.
  • Easy installation: Direct replacement with plug-and-play wiring and quick connect fittings.
  • PWM Fuel Module Controller: Electronically controls the amount of current supplied to the fuel pumps.
  • High-flow design: Features two to four high-performance fuel pumps.
  • Surge-free operation: World leading venturi systems ensure consistent fuel delivery.
  • Fuel compatible: Works with gasoline, ethanol, and methanol.
  • Optimizes power: Delivers cool, dense fuel for maximum performance.
  • Upgrade as you increase power: Modular Systems designed to upgrade as you need.
    S650 Mustang Upgraded Fuel Systems by KPM for your Supercharged Mustang mustan
Joe_Stang
Glen Burnie, Maryland
I'm new to the world of fuel upgrades on cars....what's the point in this? Will it allow us to run full e85 in our mustang?
LETHAL
From the D but in the NC
From the D to NC
It is for increased fuel flow ability on forced induction builds. The pump alone does not give the ability to run straight e85. Tuning will have to do that.
KPM Fuel Systems
KPM Fuel Systems
Adelaide
S650
Well said. We have had a lot of success with with the S550 in giving it the fuel delivery it needs for big HP and will pair perfectly with the SC options that are currently available for the S650. Our S650 customers are also seeing fuel surge completely irradicated especially on the track. Our venturi system incorporated into the module allows the pot remains full at all times.
9secondko
Irvine, ca
2003 cobra
So… this is awesome,
I can see a huge benefit for s550 cars and 6g Camaros.
For the s650, what is the purpose of running such a capable fuel system when we can’t even tune these mustangs to make use of it?
is it strictly for a smoother pull for now?
Technically it would eliminate the need for a BAP which a lot of cars are on, correct?
KPM Fuel Systems
KPM Fuel Systems
Adelaide
S650
Some Performance Shops are extracting more power than the locked Whipple or Roush kits deliver.
In this case the factory fuel system will run out of supply. This requires a larger fuel system. As far as we know, the KPM Fuel System is the only system on the market that can support this on the S650.
KPM Fuel Systems
KPM Fuel Systems
Adelaide
S650
The BAP has always been a stop gap solution to supply more fuel. The problem with the s650 is running a BAP will send the vehicle fuel system into fault mode with the extra voltage being delivered.
The KPM fuel system does not have any of these issues.
9secondko
Irvine, ca
2003 cobra
Great info. Thank you.
Rocket Man
Woodbine, MD
2016 Challenger Scat Pack Shaker, 2025 GT (soon)
very interesting. Isn't it kind of a stop gap method until/if the computer is cracked and tuning will be available?or will your setup still play nice with a tuned ecu?
KPM Fuel Systems
KPM Fuel Systems
Adelaide
S650
The KPM Fuel Systems have been developed specifically for the S650 Mustangs to support the extra power if/when the tuning becomes available.
They can run the vehicle perfectly at un-tuned standard power and if/when the tuning is available at any increase in power from standard and up to 2700HP capabilty.
We have 3 level KPM Fuel Systems ready and availble-
KPM1500
KPM2200
KPM2700
