Tire Size fitment suggestions?
s650jvn
Missouri
Hey yall I just ordered some custom rims front: 19x11 +35 offset rear: 19x11.5 +50 offset any tire size suggestions
needforspeedirl
In Front of You
2024 Mustang RTR Spec 2
Roush has a good video explaining what will fit without rubbing. 275 front and 305 rear is the widest that will fit without modification. You may have some issue with the front width at 11”.
s650jvn
Missouri
thanks I’ll check it out
MidwayJ
Dallas, Texas
285 is very common up front and Mustangs like the Mach 1 handling package and Dark Horse handling package have 305s in front.
MidwayJ
Dallas, Texas
The +35 offset won't work for 19x11 in front. The setups I've seen on the Mustang6g forum for wheels of that width are typically+24 offset in order to clear the suspension the inside. And with that offset you'll likely have a little poke on the outside.
needforspeedirl
In Front of You
I get it. What does Jack Roush know about mustangs anyway? 285 would probably be ok but not with that offset. Maybe with some negative camber adjustment but I doubt he has that option as he only stated a wheel package in the post. Why would you only want a couple mm’s of safety clearance. My RTR came with 275 fr and 295 rear. That’s wide enough. If it’s me I’m not going max without the ability to adjust the camber.
DH is not a GT.
MidwayJ
Dallas, Texas
The +35 offset won't work for a 19x11 wheel, but 285 on a 19x10 +35 wheel fits nicely in front.
