Tire size change and speedometer
gbadger
FL
Sooo… have a dark horse base. Got 305/19/30 square on the car now and the speedometer is off, which was expected. Went to Ford to have them reprogram tire size, which should be simple, and they tell me Ford “took their access away to do it” and I would need to get an aftermarket programmer
1. this seems asinine but whatever, especially since this is the tire size on the handling package
2. Is this accurate? Or was this tech wrong?
3. What is everyone else doing or has anyone else found a product that works? It seems crazy Ford locos you into whatever tire size the car was purchased with.
A.alansari
Qatar
Mustang GT 2024
I think @roket have a calculator ready to give you the exact numbers you need to use in forscan for this if I'm not mistaken
hoodscoops
NY
DH, Sti
Do you have pics? A non-HP DH with that tire setup would have a huge wheel gap. Unless you lowered it
gbadger
FL
I can get them later when I’m home but it has steeda suspension work (dual rate handling springs, camber plates, etc) so it is lower.
