Slightly loose body paneling on Driver's Side
DarkkMatter
Virginia, USA
Today I had a guy come over and checkout the car at the gas station, and he actually noticed that there was a body panel loose behind the drivers door and down low where those two body panels meet. It's close to the back end corner of the black guard that runs alongside the door.
Tried to breifly push it in to see if its something simple, but wouldnt stay.
Not that loose...maybe 1/4 inch open, but called up dealer and getting that fixed with first oil change.
I guess it is a good idea to walkaround the car every now and then if its brand now to catch things like this.
Will2
I've noticed the rear rocker panel strip (if that's what you're referring to) tends to be loose back there towards the rear of the car, I think it's normal. They are often poorly-fitted too, and set "into" the body surface more than they should be (varies from car to car and side to side). QC on these Mustangs leaves a lot to be desired, and 2025s are already much better than 2024s
Ewags81
Midwest
2024 dark horse
my passenger side is a little wonky there too. I haven't taken the time to dig into it yet
jeeptrix
Lake Havasu
2025 Mustang GT Premium
When I brought my 2025 home I noticed, also on the driver's side, the hood and fender are at different heights. The passenger side is properly lined up. Got to get it to the dealer if they ever call back.
DarkkMatter
DarkkMatter
Virginia, USA
Well, the guy at the Dealership said they were able to get it back on properly, and it looks fine now.
If it pops loose again they said to call right in, they'll order the part, paint it, and put it on under Warranty.
That is usually a simple adjustment of the hood rubber 'prong' - it screws in or out to adjust.
Starship Enterprise
MD
Fitment is not a strong point on my car. Especially the trunk. It lines up low then high against the rear quarter panel.
