S650 turn signal wiring diagram
abstruse1
2025 GT500
Greetings. I'm installing cornering lights that should be activated by the turn signals. There are 2-3 ways to do this, but the best way -- wire access permitting -- would be to switch them via the turn signal + wires that go to the right or left signal flasher. Anyone know how to access these flasher modules? Thanx.
rugedraw
Miami, FL
2021 F150 701a 3.5tt 4x4; 1990 Mustang 5.0 coupe
Wiring diagrams for the the turn signals, head and tail lights are attached.
Also attached is the diagram where the turn signal lamp is located on the front bumper. It says you need to remove the front bumper to get to it, so the diagram on how to remove the front bumper on a Mustang GT is also attached.
abstruse1
2025 GT500
Rugedraw, I really appreciate your doing this. I’ll print them out and study them.
I’m not familiar with these newfangled schematic conventions. In the past, there would be a flasher that would make/break a +12 that was energized by a switch linked to the turn signal lever. I need to find the two +12 (L and R) from that turn signal lever so as to have an uninterrupted +12, R or L, to signal the relays that operate the LED side lamps I’m installing.
Failing that, I could attach two microswitches on the steering column that would be activated by the lever.
Thanx again.
