REV745DH24
I see it! Good to know!the GTD has a wire mesh in the vents too
also, apparently Anderson Composites is making a GTD-style fender, so now im not 100% sure i will abandon the idea
It does, I've been debating on whether to get some designs on mine just to make it look better at shows.engine cover delete, i think it looks better
no cluePardon my ignorance, but what is the difference between US & Euro headlight ?
Because some countries drive on the left side of the road, the headlight are designed with a different lighting pattern than those used in the US. Long story but we shipped a BMW motorcycle to New Zealand and that was one of the changes the new owner had to make before he could take it on the road.Pardon my ignorance, but what is the difference between US & Euro headlight ?
At one point even the windshield could be/was different.Because some countries drive on the left side of the road, the headlight are designed with a different lighting pattern than those used in the US. Long story but we shipped a BMW motorcycle to New Zealand and that was one of the changes the new owner had to make before he could take it on the road.
sounds like the abs module goblin bit you finally. Did it finally start though?? ive been fortunate enough to not been bit yet.normally i unconditionally love my Mustang, but it's hard to do so when it refuses to start, stranding me at Walmart for 15 minutes. it had a bunch of invalid data and lost communication with ABS codes and the few times it did actually start, shifting into reverse shut it off
Out of curiosity did you try the socket in a pocket fix? Ie disconnect battery and reboot.normally i unconditionally love my Mustang, but it's hard to do so when it refuses to start, stranding me at Walmart for 15 minutes. it had a bunch of invalid data and lost communication with ABS codes and the few times it did actually start, shifting into reverse shut it off
yeah i went back in the store and bought a cheap ratchet and socket kit to disconnect the battery, and when i came back out everything was fine.Out of curiosity did you try the socket in a pocket fix? Ie disconnect battery and reboot.
Those are the moments one wonders, was it the ‘threat’ she/he comprehended?yeah i went back in the store and bought a cheap ratchet and socket kit to disconnect the battery, and when i came back out everything was fine.
standard paved parking lotThose are the moments one wonders, was it the ‘threat’ she comprehended?
while not really desired since they are horrendous to troubleshoot but any chance a goofy ground? How was the terrain before shutdown just prior to the anomaly?
