Rear Window Issue
SkifG
Pennsylvania
'24 Mustang GT/CS Convertible, '10 Mustang Convertible, '04 Mustang GT Convertib
When I park my car I put the top up and then put the windows up. For some reason on Friday and now yesterday the rear passenger window isn't going all the way up. Eventually after playing with the buttons it will close all the way. I've tried putting the back windows up and then the front windows, vice-versa, and putting them up at the same time. I don't see anything obvious out of alignment. I'll be taking it in for my first oil change soon and I plan to have them look at it. Has anyone else had an issue like this?
SkifG
Pennsylvania
Edit: I found a thread with a similar issue. I'll talk to the dealer about aligning the window and I'll grease the seal.
SkifG
Pennsylvania
SkifG
Pennsylvania
This is something that many convertible have on the S550.
I'm seeing that now. I've never had this issue with either of my other cars but they are pre 2015.
All my rental Mustangs in the USA had the same problem and I drove like 5 or 6 from 2015 tot 2019. I had to use my hand to close the last part.
SkifG
Pennsylvania
It's kind of crazy that they haven't solved the problem after all this time.
GrabberB
2024 Mustang GT Performance Pack, 2024 F-150, 2000 Dodge Ram 3500 800 HP Cummins
Ask the dealer to grease the seal. They'll likely use the following which you should use if you DIY this. Not cheap but good. "Krytox by Chemours GPL 205 Grease"
SkifG
Pennsylvania
Thanks! I'll check that out!
jeffnudi
Saint Marys, GA
2024 Mustang EcoBoost Prem. Conv., 2022 Mav Hy XLT
I bought a can of silicone spray when the problem started on my 2018 EcoBoost Premium Convertible. The spray can came with a tube that allowed the spray to be directed into the weatherstrip track and not get all over. Routinely did it once a year and never had the problem again. Have not had the problem with the 2024, but if it starts I am ready.
