Question about dirt gathering between car frame
Kaleza
Chicago
2024 ecoboost
Hi, i was cleaning the car today and noticed that there is a lot of dirt in the frame between door and front bumper. Also there is some sort of plastic plug (sorry, i domt know the name for it) that i think moved. Can someone double check and tell me how does it look on your car. Here are pictures and video. Thanks!
S650 Mustang Question about dirt gathering between car frame IMG_8022
S650 Mustang Question about dirt gathering between car frame IMG_8021
Kaleza
Kaleza
Chicago
2024 ecoboost
Oh I see. Yes that might be causing the debris. This is an ecoboost ?
Yea, it seems to me that that plug moved out of its place somehow and all of debris is getting in. Dont even know how to move it in its place, except taking the panel off.
D/\rK•650
2025 Mustang DarkHorse
Hey when you find out what's happening if it's not to much trouble post back, im curious to know..cheers
Will2
'26 Mustang GT
There should not be that much trash there.
The black cushion thing is supposed to be pushed up against the metal tabs that restrain it from moving further backwards.
You can access it by removing the front wheel fender liner (a few 7mm bolts and the rest are plastic push-pins), then stick your hand/tool in there and push the pad back.
Kaleza
Kaleza
Chicago
2024 ecoboost
So it needs to be in front of the metal tabs not behind. Good to know. Thank you, i will definitely do that!
