New Wheel Help!...Will Offset and Spacers Work?
GrabberHawk24
Denton, Md.
2024 Grabber Blue Mustang GT
So I have a set of rims I really like. The problem is I want a square setup not staggered. They offer the rim in a front 8.5" width (too narrow for my tire choice) and a rear 10" for a staggered setup. The 10" is perfect for my tire (285/35R20) yet the distributor says it's only good for the rear...with a 3mm spacer.
So if a 3mm (1/8") slide on spacer works for the back. Could and would a 1/4" slide on spacer give me enough offset for the front? Also would the stock wheel studs have enough threads? I have a base GT model so the brake size is of no issue and I run stock suspension. I guess it all depends on the thickness of the rim mounting surface and lug counter sink depth??? I have included pics of the rim and specs. My thought is with the +40mm offset and a 1/4" slide on hub-centric spacer i should be @+33mm offset and a 6.82" backspacing. Which theoretically should work...if the studs have enough length.
Maybe some one has these rims on a S650 already and could share their setup and pics. Even if they went with the staggered setup. Then I could see how they fit in the wheel well. I appreciate the input in advance.
S650 Mustang New Wheel Help!...Will Offset and Spacers Work? Screen Shot 2024-03-09 at 8.15.24 AM
S650 Mustang New Wheel Help!...Will Offset and Spacers Work? Screen Shot 2024-03-09 at 8.05.44 AM
S650 Mustang New Wheel Help!...Will Offset and Spacers Work? Screen Shot 2024-03-09 at 8.22.16 AM
MidwayJ
Dallas, Texas
Generally +40 offset in that size should fit front and rear, although+35 imo looks better being more flush. Not sure why these are rear only, unless there's something about the wheel shape that won't clear the non PP brakes.
I would consider these from LMR, which are designed to fit front and rear with +35 offset. Also they are flow formed construction, so probably lighter than the ones you're looking at.
https://lmr.com/item/WK-357903A/mustang-sve-r357-wheel-kit-19x10-gloss-graphite-1519
horned-toad
DC Metro
2012 Audi S5
that shape and dish won't be a problem at all. distributors are frequently wrong. Confirm their return policy and/or order just 1 to do a test fit if you're scared.
GrabberHawk24
GrabberHawk24
Denton, Md.
I appreciate the info. I really like them but, I requested LMR email me pics of them. They are really dark gray vs the Downforce which is a more silver/gray. Thank you for the suggestion though.
GrabberHawk24
GrabberHawk24
Denton, Md.
Thanks for the suggestion, I thought about that as well. It may just be my next step.
